[GRASS-dev] [GRASS GIS] #3429: g.gui.iclass: segfault when loading vector layer
trac at osgeo.org
Wed Mar 21 07:00:41 PDT 2018
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.4.1
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords: g.gui.iclass import segfault
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Trying this with current trunk, just aopplying the first part of the
patch, i.e.
Index: Vlib/open.c
--- Vlib/open.c (revision 71523)
+++ Vlib/open.c (working copy)
@@ -960,7 +960,7 @@
G_debug(1, "Vect_open_tmp_new(): name = '%s' with_z = %d", name,
with_z);
- return open_new(Map, tmp_name, with_z, TEMPORARY_MAP); /* temporary
map */
+ return open_new(Map, tmp_name, with_z, TEMPORARY_MAP_ENV); /*
temporary map */
does the trick for me.
Anna, do you remember what the second part (in frame.py) was for ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3429#comment:8>
