[GRASS-dev] Introduction
Supreet Singh Gill sharrygill5656 at gmail.com
Thu Mar 22 02:07:39 PDT 2018
I attached the fixed file.
Thank You
Supreet Singh
https://singhsupreet.github.io/
On Wed, Mar 21, 2018 at 9:17 PM, Luca Delucchi <lucadeluge at gmail.com> wrote:
> On 31 January 2018 at 15:31, sharry gill <sharrygill5656 at gmail.com> wrote:
> > Hello,
> Hi Sharry
> > I have attached a simple test, I wrote for r.mode.
> I run it in nc_basic_spm_grass7 [0] but it fails
> GRASS 7.5.svn (nc_basic_spm_grass7):~ > python ~/testrmode.py
> ERROR: Raster map <facility> not found
> E
> E
> F
> ERROR: test_1 (__main__.Testrmode)
> Traceback (most recent call last):
>   File "/home/lucadelu/testrmode.py", line 31, in test_1
>     msg="facility in degrees must be between 1 and 1")
>   File "/home/lucadelu/compilati/grass_trunk/dist.x86_64-pc-
> linux-gnu/etc/python/grass/gunittest/case.py",
> line 461, in assertRasterMinMax
>     stdout = call_module('r.info', map=map, flags='r')
> linux-gnu/etc/python/grass/gunittest/gmodules.py",
> line 131, in call_module
>     raise CalledModuleError(returncode, module, kwargs, errors)
> CalledModuleError: Module run 1 r.info ended with error
> Process ended with non-zero return code {'map': 'facility', 'flags':
> 'r', 'stderr': -1, 'stdout': -1}. See the following errors:
> ERROR: test_2 (__main__.Testrmode)
>   File "/home/lucadelu/testrmode.py", line 37, in test_2
>     msg="slope in degrees must be between 0 and 38.68939")
> Process ended with non-zero return code {'map': 'slope', 'flags': 'r',
> ERROR: Raster map <slope> not found
> FAIL: test_3 (__main__.Testrmode)
>   File "/home/lucadelu/testrmode.py", line 43, in test_3
>     msg="geology in degrees must be between 34300 and 43600")
> line 468, in assertRasterMinMax
>     self.fail(self._formatMessage(msg, stdmsg))
> AssertionError: geology in degrees must be between 34300 and 43600
> The actual minimum (217) is smaller than the reference one (34300) for
> raster map geology (with maximum 948)
> Ran 3 tests in 0.905s
> FAILED (failures=1, errors=2)
> could you please fix it?
> > I am new to Open Source community so I came early, so I can get to know
> > about OSGeo and GRASS GIS.
> > Thank You
> > Supreet
> [0] https://grass.osgeo.org/sampledata/north_carolina/nc_
> basic_spm_grass7.tar.gz
> ciao
> Luca
> www.lucadelu.org
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180322/4c903e89/attachment.html>
Type: text/x-python
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180322/4c903e89/attachment.py>
