[GRASS-dev] Introduction
Stefan Blumentrath Stefan.Blumentrath at nina.no
Thu Mar 22 04:17:40 PDT 2018
Hi guys,
For me it works partly:
python ~/testmode.py
100%
100%
F
100%
FAIL: test_2 (__main__.Testrmode)
  File "/home/stefan.blumentrath/testmode.py", line 37, in test_2
    msg="slope in degrees must be between 0 and 38.68939")
  File "/usr/local/grass-7.5.svn/etc/python/grass/gunittest/case.py", line 474, in assertRasterMinMax
    self.fail(self._formatMessage(msg, stdmsg))
AssertionError: slope in degrees must be between 0 and 38.68939
The actual maximum (72.40761) is greater than the reference one (38.68939) for raster map slope (with minimum 0)
Ran 3 tests in 1.194s
FAILED (failures=1)
Something related to region settings (e.g. when reference values were generated)?
Cheers
Stefan
From: grass-dev [mailto:grass-dev-bounces at lists.osgeo.org] On Behalf Of Supreet Singh Gill
Sent: torsdag 22. mars 2018 11.15
To: Luca Delucchi <lucadeluge at gmail.com>
Cc: GRASS-dev <grass-dev at lists.osgeo.org>
Subject: Re: [GRASS-dev] Introduction
but it is working for me, I attached the grass_cmd_output and test_keyvalue_result.
I tested on nc_spm_08_grass7
Thank You
Supreet Singh
https://singhsupreet.github.io/
On Thu, Mar 22, 2018 at 3:32 PM, Luca Delucchi <lucadeluge at gmail.com<mailto:lucadeluge at gmail.com>> wrote:
On 22 March 2018 at 10:07, Supreet Singh Gill <sharrygill5656 at gmail.com<mailto:sharrygill5656 at gmail.com>> wrote:
> Hi,
> I attached the fixed file.
still not working
> Thank You
> Supreet Singh
ciao
Luca
www.lucadelu.org<http://www.lucadelu.org>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180322/f4f173e1/attachment-0001.html>
