[GRASS-dev] [GRASS GIS] #3246: r.in.srtm: patch to support SRTM water bodies import (SWBD)
GRASS GIS trac at osgeo.org
Fri Mar 23 08:41:20 PDT 2018
  Reporter:  stjo         |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  normal       |  Milestone:  7.4.1
 Component:  Python       |    Version:  svn-releasebranch72
Resolution:               |   Keywords:  r.in.srtm
       CPU:  Unspecified  |   Platform:  All
Comment (by lucadelu):
 GDAL doesn't support this format by default, reading a little bit more
 about the data it seems that is is only the line coast and they also
 provide shapefile for this dataset
 https://lta.cr.usgs.gov/srtm_water_body_dataset
 I think the shapefile is more useful than raster, if you really need
 raster you can rasterize the vector.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3246#comment:8>
