[GRASS-dev] [GRASS GIS] #3536: python library db_table_in_vector function
GRASS GIS trac at osgeo.org
Fri Mar 23 10:17:33 PDT 2018
 Reporter:  lucadelu                             |      Owner:  grass-dev@…
     Type:  defect                               |     Status:  new
 Priority:  normal                               |  Milestone:  7.4.1
Component:  Python                               |    Version:  unspecified
 Keywords:  db_table_in_vector, db.droptable,    |        CPU:  All
  pygrass table                                  |
 Platform:  All                                  |
 The function db_table_in_vector in db.py is looking for the vector of all
 the mapset. I think this is a problem specially when it is used in
 db.droptable.
 Actually db_table_in_vector is used only in db.droptable and pygrass
 vector/table.py.
 Attached I propose to add as default to look in actual mapset.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3536>
