[GRASS-dev] [GRASS GIS] #3538: add r.clip into core modules
trac at osgeo.org
Wed Mar 28 09:24:12 PDT 2018
Reporter: martinl | Owner: grass-dev@…
Type: task | Status: new
Priority: normal | Milestone: 7.6.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.clip
CPU: Unspecified | Platform: Unspecified
Comment (by martinl):
Replying to [comment:2 Nikos Alexandris]:
> I would (re-)name it to `r.extract` or reword the label/description of
the module to read something like: "Clips out portion from the input map
based on either the extent of the current region or a vector map".
-1 `r.extract` brings more confusion which is not really necessary.
`r.clip` does the same as G7:`v.clip` - clips input raster/vector map
based on current region or vector map if defined.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3538#comment:4>
