[GRASS-dev] [GRASS GIS] #3538: add r.clip into core modules
trac at osgeo.org
Wed Mar 28 09:46:18 PDT 2018
Reporter: martinl | Owner: grass-dev@…
Type: task | Status: new
Priority: normal | Milestone: 7.6.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.clip
CPU: Unspecified | Platform: Unspecified
Comment (by Nikos Alexandris):
Replying to [comment:4 martinl]:
> Replying to [comment:2 Nikos Alexandris]:
> > I would (re-)name it to `r.extract` or reword the label/description of
the module to read something like: "Clips out portion from the input map
based on either the extent of the current region or a vector map".
> -1 `r.extract` brings more confusion which is not really necessary.
`r.clip` does the same as G7:v.clip - clips input raster/vector map based
on current region or vector map if defined.
Right, I forgot `v.clip`. However, the sentence "clips input raster/vector
map based on current region or vector map if defined" means that the the
clip action alters directly the input map. I think the original author
correctly used the wording "Extracts portion...".
Ticket URL: <https://trac.osgeo.org/grass/ticket/3538#comment:6>
