[GRASS-dev] [GRASS GIS] #3538: add r.clip into core modules
GRASS GIS trac at osgeo.org
Wed Mar 28 12:13:22 PDT 2018
  Reporter:  martinl      |      Owner:  grass-dev@…
      Type:  task         |     Status:  new
  Priority:  normal       |  Milestone:  7.6.0
 Component:  Raster       |    Version:  svn-trunk
Resolution:               |   Keywords:  r.clip
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by veroandreo):
 Replying to [comment:4 martinl]:
 > Replying to [comment:2 Nikos Alexandris]:
 > > I would (re-)name it to `r.extract` or reword the label/description of
 the module to read something like: "Clips out portion from the input map
 based on either the extent of the current region or a vector map".
 > -1 `r.extract` brings more confusion which is not really necessary.
 `r.clip` does the same as G7:v.clip - clips input raster/vector map based
 on current region or vector map if defined.
 +1 for using "clip" instead of "extract" in both G7:v.clip and G7A:r.clip.
 I think "clip" is clear enough and is a well known operation in GIS.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3538#comment:8>
