[GRASS-dev] [GRASS GIS] #3532: g.gui.tplot: add zonal statistics support
GRASS GIS trac at osgeo.org
Wed Mar 28 14:32:29 PDT 2018
  Reporter:  veroandreo  |      Owner:  grass-dev@…
      Type:              |     Status:  new
  enhancement            |
  Priority:  normal      |  Milestone:  7.6.0
 Component:  wxGUI       |    Version:  svn-trunk
Resolution:              |   Keywords:  g.gui.tplot, temporal, zonal
       CPU:              |  statistics
  Unspecified            |   Platform:  Linux
Comment (by lucadelu):
 The attached diff implements support for r.univar to calculate statistic
 for a vector map used as MASK.
 Right now only mean value is used because there is a problem with a
 gselect.ElementSelect, the element seems to be disabled, could some one
 check it, because I don't understand where is the error. I also tested
 Enable function but it doesn't change the behaviour.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3532#comment:1>
