[GRASS-dev] [EXTERNAL] [GRASS GIS] #3560: r.in.lidar: error to open valid LAZ file
Newcomb, Doug
doug_newcomb at fws.gov
Wed May 9 12:17:33 PDT 2018
Markus,
Liblas reads LAS version 1.2 , which is limited to 4.2 billion points. You
have to compile liblas with an older version of laszip .
Doug
> Reporter: neteler | Owner: grass-dev@…
> Type: defect | Status: new
> Priority: normal | Milestone: 7.4.1
> Component: Raster | Version: svn-releasebranch74
> Keywords: r.in.lidar | CPU: Unspecified
> Platform: All |
> We currently fail to import a larger LiDAR file (LAZ)
> pdal info dom1l_fp_tr_gebiet.laz > meta.txt
> head -n 300 meta.txt
> "filename": "dom1l_fp_tr_gebiet.laz",
> "pdal_version": "1.7.0 (git-version: Release)",
> "stats":
> "bbox":
> "EPSG:4326":
> "bbox":
> "maxx": 7.311614961,
> "maxy": 50.83646173,
> "maxz": 344.69,
> "minx": 7.196437705,
> "miny": 50.78981976,
> "minz": 56.12
> "boundary": {
> "coordinates" :
> 7.1981681200000001,
> 50.78981976
> "statistic":
> "average": 377073.6011,
> "count": 297683873,
> "kurtosis": -4.436009717e+18,
> "maximum": 381000,
> "minimum": 373000,
> "name": "X",
> "position": 0,
> "skewness": 5.047057151e+17,
> "stddev": 1853.891145,
> "variance": 3436912.377
> This file was created with "pdal merge" from several LAZ tiles.
> Now, the import fails without any specific explanation:
> GRASS 7.4.1svn (lidar):/scratch/kaldauen_klassifikation >
> r.in.lidar imput=dom1l_fp_tr_gebiet.laz out=bla
> FEHLER: Unable to open file <dom1l_fp_tr_gebiet.laz>
> as a LiDAR point cloud
> g.gisenv set="DEBUG=3"
> D1/3: G_set_program_name(): r.in.lidar
> D2/3: G_file_name(): path = /home/mundialis/grassdata/lidar/anika
> lidar/anika/cell/bla
> D2/3: G_file_name(): path = /home/mundialis/grassdata/lidar/anika/WIND
> D2/3: file open: read (mode = r)
> D2/3: G__read_Cell_head
> D2/3: G__read_Cell_head_array
> D3/3: region item: proj: 99
> D3/3: region item: zone: 0
> D3/3: region item: north: 5631000
> D3/3: region item: south: 5628000
> D3/3: region item: east: 379002
> D3/3: region item: west: 375000
> D3/3: region item: cols: 1334
> D3/3: region item: rows: 1000
> D3/3: region item: e-w resol: 3
> D3/3: region item: n-s resol: 3
> D3/3: region item: top: 1.000000000000000
> D3/3: region item: bottom: 0.000000000000000
> D3/3: region item: cols3: 1334
> D3/3: region item: rows3: 1000
> D3/3: region item: depths: 1
> D3/3: region item: e-w resol3: 3
> D3/3: region item: n-s resol3: 3
> D3/3: region item: t-b resol: 1
> D1/3: G_set_program_name(): g.gisenv
> D3/3: G_option_to_separator(): key = separator -> sep = '/'
> To be sure, a check if liblas was compiled with LAZ support:
> ldd `which r.in.lidar`
> linux-vdso.so.1 (0x00007fff91df4000)
> libgrass_raster.7.4.1svn.so =>
> /home/mundialis/software/grass74_svn/dist.x86_64-pc-linux-
> gnu/lib/libgrass_raster.7.4.1svn.so 0x00007f225909b000)
> libgrass_gis.7.4.1svn.so =>
> gnu/lib/libgrass_gis.7.4.1svn.so (0x00007f2258e42000)
> libm.so.6 => /lib64/libm.so.6 (0x00007f2258af7000)
> libgrass_gproj.7.4.1svn.so =>
> gnu/lib/libgrass_gproj.7.4.1svn.so (0x00007f22588ec000)
> liblas.so.3 => /lib64/liblas.so.3 (0x00007f225862b000)
> liblas_c.so.3 => /lib64/liblas_c.so.3 (0x00007f22583f4000)
> libboost_program_options.so.1.64.0 =>
> /lib64/libboost_program_options.so.1.64.0 (0x00007f2258179000)
> libboost_regex.so.1.64.0 => /lib64/libboost_regex.so.1.64.0
> (0x00007f225454c000)
> libstdc++.so.6 => /lib64/libstdc++.so.6 (0x00007f22541c5000)
> libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007f2253fae000)
> librt.so.1 => /lib64/librt.so.1 (0x00007f2253da6000)
> libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f2253b88000)
> libarmadillo.so.7 => /lib64/libarmadillo.so.7 (0x00007f225397f000)
> libpoppler.so.68 => /lib64/libpoppler.so.68 (0x00007f22534da000)
> libjson-c.so.2 => /lib64/libjson-c.so.2 (0x00007f22532cf000)
> libfreexl.so.1 => /lib64/libfreexl.so.1 (0x00007f22530c6000)
> libgeos_c.so.1 => /lib64/libgeos_c.so.1 (0x00007f2252e95000)
> libwebp.so.7 => /lib64/libwebp.so.7 (0x00007f2252c27000)
> gnu/lib/libgrass_rtree.7.4.1svn.so (0x00007f2248669000)
> libbz2.so.1 => /lib64/libbz2.so.1 (0x00007f2248458000)
> libicudata.so.57 => /lib64/libicudata.so.57 (0x00007f22469db000)
> # limit check to "las" string:
> ldd `which r.in.lidar` | grep las
> liblas.so.3 => /lib64/liblas.so.3 (0x00007faa54b94000)
> liblas_c.so.3 => /lib64/liblas_c.so.3 (0x00007faa5495d000)
> liblaszip.so.8 => /lib64/liblaszip.so.8 (0x00007faa528ce000)
> libopenblaso.so.0 => /lib64/libopenblaso.so.0 (0x00007faa401eb000)
> libblas.so.3 => /lib64/libblas.so.3 (0x00007faa3a078000)
> libopenblasp.so.0 => /lib64/libopenblasp.so.0 (0x00007faa37b34000)
> libsatlas.so.3 => /usr/lib64/atlas/libsatlas.so.3
> (0x00007faa36b25000)
> So, liblaszip is present, i.e. LAZ support should be ok.
> System:
> lsb_release -a
> LSB Version: :core-4.1-amd64:core-4.1-noarch
> Distributor ID: Fedora
> Description: Fedora release 27 (Twenty Seven)
> Release: 27
> Codename: TwentySeven
> Any ideas how to debug this properly? (I can test on trunk as well)
> Does the LAZ file size matter?
> Ticket URL: <https://trac.osgeo.org/grass/ticket/3560>
> GRASS GIS <https://grass.osgeo.org>
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
Doug Newcomb
USFWS
551F Pylon Dr
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb at fws.gov
*NOTE: This email correspondence and any attachments to and from this
sender is subject to the Freedom of Information Act (FOIA) and may be
disclosed to third parties.*
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180509/094ea57f/attachment-0001.html>
