[GRASS-dev] remove raster map in C code
Markus Metz
markus.metz.giswork at gmail.com
Fri May 11 07:32:44 PDT 2018
On Fri, May 11, 2018 at 11:54 AM, Luca Delucchi <lucadeluge at gmail.com>
wrote:
> On 11 May 2018 at 10:54, Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> > Hi Luca,
> Hi Markus,
> > On Fri, May 11, 2018 at 10:26 AM, Luca Delucchi <lucadeluge at gmail.com>
> > wrote:
> >> Hi devs,
> >> I would like to remove a raster map inside a C module, looking aroung
> >> I found the M_do_remove function used in g.remove and r.reclass. So I
> >> tried to use it but I get error in compilation
> >> OBJ.x86_64-pc-linux-gnu/main.o: In function `main':
> >> main.c:(.text.startup+0x9eb): undefined reference to `M_get_element'
> >> main.c:(.text.startup+0x9f5): undefined reference to `M_do_remove'
> >> collect2: error: ld returned 1 exit status
> > this is a problem of the linker: you need to link against the manage
lib,
> > see e.g. the Makefile for g.remove. Try
> > LIBES = $(MANAGELIB) $(RASTERLIB) $(GISLIB)
> > DEPENDENCIES = $(MANAGEDEP) $(RASTERDEP) $(GISDEP)
> > in the Makefile of your module.
> thanks, now it compile but I get "Segmentation fault", the module is
> r.tile, I attached the diff, could someone have a look to it please?
I think you need to call M_read_list() first, before you loop over the
tiles.
Markus M
> > HTH,
> > Markus M
> ciao
> Luca
> www.lucadelu.org
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180511/891744b7/attachment.html>
