[GRASS-dev] [GRASS GIS] #3361: v.select: very slow using GEOS operators
trac at osgeo.org
Mon May 14 13:27:41 PDT 2018
Reporter: mlennert | Owner: grass-dev@…
Type: enhancement | Status: closed
Priority: normal | Milestone: 7.4.1
Component: Vector | Version: svn-trunk
Resolution: fixed | Keywords: v.select GEOS within slow
CPU: Unspecified | Platform: Unspecified
Comment (by mmetz):
Replying to [comment:4 mmetz]:
> In [changeset:"72705" 72705]:
> #!CommitTicketReference repository="" revision="72705"
> v.select: re-organize code to select features from vector map A by
features from other vector map B (fixes #3361)
Assuming that the result will be a subset of map A, selected by features
from map B, the code re-organization results in a substantial speed-up.
v.select is now nearly as fast as the alternative in the description.
The results of `operator=overlap` and the GEOS-equivalent
`operator=intersects` are identical, but the speed difference based on the
example in the description
v.select ain=boundary_municp bin=rail5000 out=select op=overlap/intersects
is astonishing, as of trunk r72705.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3361#comment:5>
