[GRASS-dev] [GRASS GIS] #3546: t.rast.what: issues in one_point_per_col_output()
trac at osgeo.org
Tue May 15 12:23:17 PDT 2018
Reporter: sbl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.4.1
Component: Temporal | Version: 7.4.0
Resolution: | Keywords: t.rast.what
CPU: All | Platform: All
Comment (by veroandreo):
I tested the fix following the example in trunk (with the fix) and in
release branch. Personally, I would prefer to get only cat number when
using -v flag. Default could still be the coords (-n) and -v only cat
values.
Moreover, testing different layouts, I found that when using
`layout=timerow`, there's an extra empty column or line according if I use
-vn or only -v (but this also happens in release branch, without the fix):
t.rast.what strds=A points=points layout=timerow -vn
cat|x|y|1990-01-01 00:00:00;1990-02-01 00:00:00|1990-02-01
00:00:00;1990-03-01 00:00:00|1990-03-01 00:00:00;1990-04-01
00:00:00|1990-04-01 00:00:00;1990-05-01 00:00:00
1|115.004358627375|36.3593955782903||1|2|3|4
2|79.681676382576|45.2391522852909||1|2|3|4
3|97.4892579600048|79.2347263950131||1|2|3|4
Ticket URL: <https://trac.osgeo.org/grass/ticket/3546#comment:6>
