[GRASS-dev] [GRASS GIS] #3546: t.rast.what: issues in one_point_per_col_output()
GRASS GIS trac at osgeo.org
Tue May 15 15:19:34 PDT 2018
  Reporter:  sbl       |      Owner:  grass-dev@…
      Type:  defect    |     Status:  new
  Priority:  normal    |  Milestone:  7.4.1
 Component:  Temporal  |    Version:  7.4.0
Resolution:            |   Keywords:  t.rast.what
       CPU:  All       |   Platform:  All
Comment (by sbl):
 Thanks for testing! If there is agreement on removing coordinates if cat
 is used, I can change that. Not sure if that can go to 7.4, though???
 Please also test attached new diff that fixes the empty column in the
 timerow output and an empty line if header is not requested...
 Looks now like this:
 t.rast.what strds=A points=points layout=timerow -v
 1|115.004358627375|36.3593955782903|1|2|3|4
 2|79.681676382576|45.2391522852909|1|2|3|4
 3|97.4892579600048|79.2347263950131|1|2|3|4
 t.rast.what strds=A points=points layout=timerow -vn
 cat|x|y|1990-01-01 00:00:00;1990-02-01 00:00:00|1990-02-01
 00:00:00;1990-03-01 00:00:00|1990-03-01 00:00:00;1990-04-01
 00:00:00|1990-04-01 00:00:00;1990-05-01 00:00:00
 echo "115 36 Loc1
 79 45 Loc2" | t.rast.what -i strds=A layout=timerow -n separator=','
 x,y,site,1990-01-01 00:00:00;1990-02-01 00:00:00,1990-02-01
 00:00:00;1990-03-01 00:00:00,1990-03-01 00:00:00;1990-04-01
 00:00:00,1990-04-01 00:00:00;1990-05-01 00:00:00
 115,36,Loc1,1,2,3,4
 79,45,Loc2,1,2,3,4
Ticket URL: <https://trac.osgeo.org/grass/ticket/3546#comment:7>
