[GRASS-dev] Regarding testing
Luca Delucchi
lucadeluge at gmail.com
Tue May 15 18:47:40 PDT 2018
On 13 May 2018 at 08:12, Sanjeet <edu.sanjeet at gmail.com> wrote:
> On Wed, May 9, 2018 at 3:30 AM, Luca Delucchi <lucadeluge at gmail.com> wrote:
>> On 8 May 2018 at 07:39, Sanjeet <edu.sanjeet at gmail.com> wrote:
>>> I made some minor changes in 'utils.py' in lib/python/script and
>>> 'test_utils.py' in its testsuite.
>>> https://github.com/sanjeetbhatti/FullSupportPython3/blob/master/patch.diff
>>> The Python 3's bytes cannot contain ASCII literal characters,
>>> therefore I can't seem to test it as such, I encoded it first before
>>> checking for an assertion, which I am not sure is a correct way to do
>>> so as we are ensuring that we do not pass any bytes with ASCII literal
>>> characters.
>> could be this a problem with languages using strange accent mark?
>> We had and have problem with some languages in translations
>>> Same thing is in test_start_command_functions.py.
>>> Moreover, I generalized the encode and decode functions by using
>>> string conversion for int and float values.
>>> Please let me know if this is the correct way to go about it.
>> It seems correct to me, but please Anna answer
> Hi Anna and Luca,
Hi Sanjeet
> I have been working with scripts and testing them with python3 and I
> made some changes in 2 different patches:
> 1. patch.diff -> has changes for unicode/bytes in utils and its
> test_utils.py along with test_start_command_functions.py (depending on
> the changes in utils)
> 2. raster.diff -> has changes for raster.py
What other devs think about the patches?
They seem ok for me, I tested and they work
> Please take a look here:
> For other tests, I have created a google sheet:
> https://docs.google.com/spreadsheets/d/1eAIJtegNWSbBscFChhQzMTl0vmbGPjmrW_013hSw9bI
A comment about results, for me the test_doctest.py is working fine
with Python 3.5.3
100%
100%
Loading floating point data with 8 bytes ... (6x4x3)
100%
100%
Ran 1 test in 0.785s
OK
> I'm working on few other testsuites and hoping to have a couple of
> patches submitted by tomorrow.
> Thanks
> Sanjeet Bhatti
ciao
Luca
www.lucadelu.org
