[GRASS-dev] [GRASS GIS] #3546: t.rast.what: issues in one_point_per_col_output()
GRASS GIS trac at osgeo.org
Wed May 16 03:18:04 PDT 2018
  Reporter:  sbl       |      Owner:  grass-dev@…
      Type:  defect    |     Status:  new
  Priority:  normal    |  Milestone:  7.4.1
 Component:  Temporal  |    Version:  7.4.0
Resolution:            |   Keywords:  t.rast.what
       CPU:  All       |   Platform:  All
Comment (by sbl):
 BTW, 4 unit tests are failing in current release branch:
 FAIL: test_col_output (__main__.TestRasterWhat)
 AssertionError: File <out_col.txt> does not have the right MD5 sum.
 Expected is <8720cc237b46ddb18f11440469d0e13f>, actual is
 <885b6f50405b08fa9fe9ae33ed50e29b>
 FAIL: test_col_output_cat (__main__.TestRasterWhat)
 AssertionError: File <out_col_cat.txt> does not have the right MD5 sum.
 Expected is <e1d8e6651b3bff1c35e366e48d634db4>, actual is
 <ac0a9b14e59920c3f8b5834282a24822>
 FAIL: test_col_output_coords (__main__.TestRasterWhat)
 AssertionError: File <out_col_coords.txt> does not have the right MD5 sum.
 Expected is <ac44ebc5aa040d4ce2a5787e95f208ec>, actual is
 <ecdc79a6880a9e1f163cc92fa384b8a3>
 FAIL: test_timerow_output_cat (__main__.TestRasterWhat)
 AssertionError: File <out_col_trow.txt> does not have the right MD5 sum.
 Expected is <55e2ff8ddaeb731a73daca48adf2768d>, actual is
 <1da3350f488df9c919b4009625956b3b>
Ticket URL: <https://trac.osgeo.org/grass/ticket/3546#comment:11>
