[GRASS-dev] [GRASS-SVN] r72715 - grass/branches/releasebranch_7_4/vector/v.select
Martin Landa landa.martin at gmail.com
Wed May 16 12:59:07 PDT 2018
2018-05-16 21:49 GMT+02:00  <svn_grass at osgeo.org>:
> Log:
> v.select: backport trunk r73705, r72714
first of all, great job!
Just a small note, please be more informative in log messages also
about backporting. It will help going through svn log when collecting
news for release. Thanks, Martin
> -    return relate_geos(BIn, AGeom, bline, operator, relate, 0);
> +    return relate_geos(AIn, BGeom, aline, operator, relate, 0);
> -int area_relate_geos(struct Map_info *BIn, const GEOSGeometry * AGeom,
> -                    int barea, int operator, const char *relate)
> +int area_relate_geos(struct Map_info *AIn, const GEOSGeometry *BGeom,
> +                    int aarea, int operator, const char *relate)
> -    return relate_geos(BIn, AGeom, barea, operator, relate, 1);
> +    return relate_geos(AIn, BGeom, aarea, operator, relate, 1);
> -int relate_geos(struct Map_info *BIn, const GEOSGeometry * AGeom,
> -               int bfid, int operator, const char *relate, int area)
> +int relate_geos(struct Map_info *AIn, const GEOSGeometry *BGeom,
> +               int afid, int operator, const char *relate, int area)
> -    GEOSGeometry *BGeom = NULL;
> +    GEOSGeometry *AGeom = NULL;
>      int found;
>      found = 0;
>      if (area)
> -       BGeom = Vect_read_area_geos(BIn, bfid);
> +       AGeom = Vect_read_area_geos(AIn, afid);
>      else
> -       BGeom = Vect_read_line_geos(BIn, bfid, NULL);
> +       AGeom = Vect_read_line_geos(AIn, afid, NULL);
> -    if (!BGeom)
> +    if (!AGeom)
>         return 0;
> @@ -115,8 +115,8 @@
>         break;
> -    if (BGeom)
> -       GEOSGeom_destroy(BGeom);
> +    if (AGeom)
> +       GEOSGeom_destroy(AGeom);
>      return found;
> Modified: grass/branches/releasebranch_7_4/vector/v.select/main.c
> --- grass/branches/releasebranch_7_4/vector/v.select/main.c     2018-05-16 19:42:14 UTC (rev 72714)
> +++ grass/branches/releasebranch_7_4/vector/v.select/main.c     2018-05-16 19:49:20 UTC (rev 72715)
> @@ -113,9 +113,7 @@
>      /* Alloc space for input lines array */
>      ALines = (int *)G_calloc(Vect_get_num_lines(&(In[0])) + 1, sizeof(int));
> -    AAreas = NULL;
> -    if (flag.reverse->answer)
> -       AAreas = (int *)G_calloc(Vect_get_num_areas(&(In[0])) + 1, sizeof(int));
> +    AAreas = (int *)G_calloc(Vect_get_num_areas(&(In[0])) + 1, sizeof(int));
>      /* Read field info */
>      IFi = Vect_get_field(&(In[0]), ifield[0]);
> @@ -150,47 +148,56 @@
>      finishGEOS();
>  #endif
> +    if (!flag.reverse->answer) {
> +       G_free(AAreas);
> +       AAreas = NULL;
>      if (nfound != 0) {
> -    native = Vect_maptype(&Out) == GV_FORMAT_NATIVE;
> +       native = Vect_maptype(&Out) == GV_FORMAT_NATIVE;
> -    nfields = Vect_cidx_get_num_fields(&(In[0]));
> -    cats = (int **)G_malloc(nfields * sizeof(int *));
> -    ncats = (int *)G_malloc(nfields * sizeof(int));
> -    fields = (int *)G_malloc(nfields * sizeof(int));
> +       nfields = Vect_cidx_get_num_fields(&(In[0]));
> +       cats = (int **)G_malloc(nfields * sizeof(int *));
> +       ncats = (int *)G_malloc(nfields * sizeof(int));
> +       fields = (int *)G_malloc(nfields * sizeof(int));
> -    /* Write lines */
> -    if (!flag.table->answer && !native) {
> -       /* Copy attributes for OGR output */
> -       Vect_copy_map_dblinks(&(In[0]), &Out, TRUE);
> -    write_lines(&(In[0]), IFi, ALines, AAreas,
> -               &Out, flag.table->answer ? 1 : 0, flag.reverse->answer ? 1 : 0,
> -               nfields, fields, ncats, cats);
> +       /* Write lines */
> +       if (!flag.table->answer && !native) {
> +           /* Copy attributes for OGR output */
> +           Vect_copy_map_dblinks(&(In[0]), &Out, TRUE);
> +       write_lines(&(In[0]), IFi, ALines, AAreas,
> +                   &Out, flag.table->answer ? 1 : 0, flag.reverse->answer ? 1 : 0,
> +                   nfields, fields, ncats, cats);
> -    /* Copy tables */
> -    if (!flag.table->answer && native) {
> -       copy_tabs(&(In[0]), &Out,
> +       /* Copy tables */
> +       if (!flag.table->answer && native) {
> +           copy_tabs(&(In[0]), &Out,
> -    /* print info about skipped features & close input maps */
> -    for (iopt = 0; iopt < 2; iopt++) {
> -        if (nskipped[iopt] > 0) {
> -            G_warning(_("%d features from <%s> without category skipped"),
> -                      nskipped[iopt], Vect_get_full_name(&(In[iopt])));
> -        Vect_close(&(In[iopt]));
> +       /* print info about skipped features & close input maps */
> +       for (iopt = 0; iopt < 2; iopt++) {
> +           if (nskipped[iopt] > 0) {
> +               G_warning(_("%d features from <%s> without category skipped"),
> +                         nskipped[iopt], Vect_get_full_name(&(In[iopt])));
> +           Vect_close(&(In[iopt]));
> -    Vect_build(&Out);
> -    Vect_close(&Out);
> +       Vect_build(&Out);
> +       Vect_close(&Out);
> -    G_done_msg(_("%d features written to output."), Vect_get_num_lines(&Out));
> -    } else {
> -    G_done_msg(_("No features found !"));
> +       G_done_msg(_("%d features written to output."), Vect_get_num_lines(&Out));
> +    else {
> +       Vect_close(&In[0]);
> +       Vect_close(&In[1]);
> +       G_done_msg(_("No features found !"));
>      exit(EXIT_SUCCESS);
> Modified: grass/branches/releasebranch_7_4/vector/v.select/overlap.c
> --- grass/branches/releasebranch_7_4/vector/v.select/overlap.c  2018-05-16 19:42:14 UTC (rev 72714)
> +++ grass/branches/releasebranch_7_4/vector/v.select/overlap.c  2018-05-16 19:49:20 UTC (rev 72715)
> @@ -40,43 +40,17 @@
>  /* Returns 1 if line1 from Map1 overlaps area2 from Map2,
>   *         0 otherwise */
> -int line_overlap_area(struct line_pnts *LPoints, struct Map_info *AMap,
> -                     int area)
> +int line_overlap_area(struct line_pnts *LPoints, struct line_pnts *OPoints,
> +                     struct line_pnts **IPoints, int nisles)
> -    int i, nisles, isle;
> -    static struct line_pnts *APoints = NULL;
> -    static struct line_pnts **IPoints = NULL;
> -    static int isles_alloc = 0;
> +    int i, isle;
> -    G_debug(4, "line_overlap_area area = %d", area);
> +    G_debug(4, "line_overlap_area area");
> -    if (!APoints) {
> -       APoints = Vect_new_line_struct();
> -       isles_alloc = 10;
> -       IPoints = G_malloc(isles_alloc * sizeof(struct line_pnts *));
> -       for (i = 0; i < isles_alloc; i++)
> -           IPoints[i] = Vect_new_line_struct();
> -    Vect_get_area_points(AMap, area, APoints);
> -    nisles = Vect_get_area_num_isles(AMap, area);
> -    if (nisles >= isles_alloc) {
> -       IPoints = G_realloc(IPoints, (nisles + 10) * sizeof(struct line_pnts *));
> -       for (i = isles_alloc; i < nisles + 10; i++)
> -       isles_alloc = nisles + 10;
> -    for (i = 0; i < nisles; i++) {
> -       isle = Vect_get_area_isle(AMap, area, i);
> -       Vect_get_isle_points(AMap, isle, IPoints[i]);
>      /* Try if any of line vertices is within area */
>      for (i = 0; i < LPoints->n_points; i++) {
> -       if (Vect_point_in_poly(LPoints->x[i], LPoints->y[i], APoints)) {
> +       if (Vect_point_in_poly(LPoints->x[i], LPoints->y[i], OPoints)) {
>             int inside = 1;
>             for (isle = 0; isle < nisles; isle++) {
> @@ -99,13 +73,12 @@
>      /* Try intersections of line with area/isles boundary */
>      /* Outer boundary */
> -    if (Vect_line_check_intersection2(LPoints, APoints, 0)) {
> +    if (Vect_line_check_intersection2(LPoints, OPoints, 0)) {
>         G_debug(4, "  -> line intersects outer area boundary");
>         return 1;
>         if (Vect_line_check_intersection2(LPoints, IPoints[i], 0)) {
>             G_debug(4, "  -> line intersects area island boundary");
>             return 1;
> Modified: grass/branches/releasebranch_7_4/vector/v.select/proto.h
> --- grass/branches/releasebranch_7_4/vector/v.select/proto.h    2018-05-16 19:42:14 UTC (rev 72714)
> +++ grass/branches/releasebranch_7_4/vector/v.select/proto.h    2018-05-16 19:49:20 UTC (rev 72715)
> @@ -42,7 +42,8 @@
>  /* overlap.c */
>  void add_aarea(struct Map_info *, int, int *, int *);
> -int line_overlap_area(struct line_pnts *, struct Map_info *, int);
> +int line_overlap_area(struct line_pnts *, struct line_pnts *,
> +                      struct line_pnts **, int);
>  /* write.c */
>  void write_lines(struct Map_info *, struct field_info *, int *, int *,
> Modified: grass/branches/releasebranch_7_4/vector/v.select/select.c
> --- grass/branches/releasebranch_7_4/vector/v.select/select.c   2018-05-16 19:42:14 UTC (rev 72714)
> +++ grass/branches/releasebranch_7_4/vector/v.select/select.c   2018-05-16 19:49:20 UTC (rev 72715)
> @@ -7,327 +7,404 @@
>  #include "proto.h"
>  int select_lines(struct Map_info *aIn, int atype, int afield,
> -                  struct Map_info *bIn, int btype, int bfield,
> -                  int cat_flag, int operator, const char *relate,
> -                  int *ALines, int *AAreas, int* nskipped)
> +                 struct Map_info *bIn, int btype, int bfield,
> +                 int cat_flag, int operator, const char *relate,
> +                 int *ALines, int *AAreas, int* nskipped)
> -    int i;
> -    int nalines, aline, ltype;
> +    int i, ai;
> +    int nblines, bline, ltype;
>      int nfound = 0;
>      struct line_pnts *APoints, *BPoints;
> -    struct ilist *BoundList, *LList;
> -    struct boxlist *List, *TmpList;
> +    struct line_pnts *OPoints, **IPoints;
> +    int isle, nisles, isles_alloc;
> +    struct ilist *BoundList;
> +    struct boxlist *List;
>  #ifdef HAVE_GEOS
>      initGEOS(G_message, G_fatal_error);
> -    GEOSGeometry *AGeom = NULL;
> +    GEOSGeometry *BGeom = NULL;
>  #else
> -    void *AGeom = NULL;
> +    void *BGeom = NULL;
>  #endif
>      nskipped[0] = nskipped[1] = 0;
>      BPoints = Vect_new_line_struct();
> +    OPoints = Vect_new_line_struct();
> +    isles_alloc = 10;
> +    IPoints = G_malloc(isles_alloc * sizeof(struct line_pnts *));
> +    for (i = 0; i < isles_alloc; i++)
> +       IPoints[i] = Vect_new_line_struct();
> +    nisles = 0;
>      List = Vect_new_boxlist(1);
> -    TmpList = Vect_new_boxlist(1);
>      BoundList = Vect_new_list();
> -    LList = Vect_new_list();
> -    nalines = Vect_get_num_lines(aIn);
> +    nblines = Vect_get_num_lines(bIn);
> -    /* Lines in A. Go through all lines and mark those that meets condition */
> -    if (atype & (GV_POINTS | GV_LINES)) {
> +    /* Lines in B */
> +    if (btype & (GV_POINTS | GV_LINES)) {
>         G_message(_("Processing features..."));
> -       G_percent(0, nalines, 2);
> -       for (aline = 1; aline <= nalines; aline++) {
> -           struct bound_box abox;
> +       G_percent(0, nblines, 2);
> +       for (bline = 1; bline <= nblines; bline++) {
> +           struct bound_box bbox;
> -           G_debug(3, "aline = %d", aline);
> -           G_percent(aline, nalines, 2);       /* must be before any continue */
> +           G_debug(3, "bline = %d", bline);
> +           G_percent(bline, nblines, 1);       /* must be before any continue */
> +           /* Check type */
> +           ltype = Vect_get_line_type(bIn, bline);
> +           if (!(ltype & btype))
> +               continue;
>             /* Check category */
> -           if (!cat_flag && Vect_get_line_cat(aIn, aline, afield) < 0) {
> -               nskipped[0]++;
> +           if (!cat_flag && Vect_get_line_cat(bIn, bline, bfield) < 0) {
> +               nskipped[1]++;
>                 continue;
> -           /* Read line and check type */
> -           if (operator != OP_OVERLAP) {
> -#ifdef HAVE_GEOS
> -               AGeom = Vect_read_line_geos(aIn, aline, &ltype);
> -#endif
> -               if (!(ltype & (GV_POINT | GV_LINE)))
> -                   continue;
> +           Vect_reset_line(BPoints);
> -               if (!AGeom)
> -                   G_fatal_error(_("Unable to read line id %d from vector map <%s>"),
> -                                 aline, Vect_get_full_name(aIn));
> -           else {
> -               ltype = Vect_read_line(aIn, APoints, NULL, aline);
> -           if (!(ltype & atype))
> -               continue;
> -           Vect_get_line_box(aIn, aline, &abox);
> +           Vect_get_line_box(bIn, bline, &bbox);
> -           /* Check if this line overlaps any feature in B */
> -           /* x Lines in B */
> -           if (btype & (GV_POINTS | GV_LINES)) {
> -               int found = 0;
> +           /* Check if this line overlaps any feature in A */
> +           /* x Lines in A */
> +           if (atype & (GV_POINTS | GV_LINES)) {
>                 /* Lines */
> -               Vect_select_lines_by_box(bIn, &abox, btype, List);
> -               for (i = 0; i < List->n_values; i++) {
> -                   int bline;
> +               Vect_select_lines_by_box(aIn, &bbox, atype, List);
> +               for (ai = 0; ai < List->n_values; ai++) {
> +                   int aline;
> -                   bline = List->id[i];
> -                   G_debug(3, "  bline = %d", bline);
> +                   aline = List->id[ai];
> +                   G_debug(3, "  aline = %d", aline);
> +                   if (ALines[aline] == 1)
> +                       continue;
> +                   /* Check type */
> +                   ltype = Vect_get_line_type(aIn, aline);
> +                   if (!(ltype & atype))
> +                       continue;
>                     if (!cat_flag &&
> -                       Vect_get_line_cat(bIn, bline, bfield) < 0) {
> -                       nskipped[1]++;
> +                       Vect_get_line_cat(aIn, aline, afield) < 0) {
> +                       nskipped[0]++;
>                         continue;
>  #ifdef HAVE_GEOS
> -                       if(line_relate_geos(bIn, AGeom,
> -                                           bline, operator, relate)) {
> +                       if (!BGeom)
> +                           BGeom = Vect_read_line_geos(bIn, bline, &ltype);
> +                       if (!BGeom)
> +                           G_fatal_error(_("Unable to read line id %d from vector map <%s>"),
> +                                         bline, Vect_get_full_name(bIn));
> -                           found = 1;
> -                           break;
> +                       if (line_relate_geos(aIn, BGeom, aline,
> +                                            operator, relate)) {
> +                           ALines[aline] = 1;
> +                           nfound += 1;
>  #endif
>                     else {
> -                       Vect_read_line(bIn, BPoints, NULL, bline);
> +                       if (BPoints->n_points == 0)
> +                           Vect_read_line(bIn, BPoints, NULL, bline);
> +                       Vect_read_line(aIn, APoints, NULL, aline);
> -                       if (Vect_line_check_intersection2(APoints, BPoints, 0)) {
> -                           found = 1;
> -                           break;
> +                       if (Vect_line_check_intersection2(BPoints, APoints, 0)) {
> +                           nfound += 1;
> -               if (found) {
> -                   ALines[aline] = 1;
> -                   nfound += 1;
> -                   continue;   /* Go to next A line */
> -           /* x Areas in B. */
> -           if (btype & GV_AREA) {
> +           /* x Areas in A. */
> +           if (atype & GV_AREA) {
> -               Vect_select_areas_by_box(bIn, &abox, List);
> -                   int barea;
> +               Vect_select_areas_by_box(aIn, &bbox, List);
> +                   int aarea;
> -                   barea = List->id[i];
> -                   G_debug(3, "  barea = %d", barea);
> +                   aarea = List->id[ai];
> +                   G_debug(3, "  aarea = %d", aarea);
> -                   if (Vect_get_area_cat(bIn, barea, bfield) < 0) {
> -                       nskipped[1]++;
> +                   if (AAreas[aarea] == 1)
>                         continue;
> +                   if (Vect_get_area_centroid(aIn, aarea) < 1)
> +                       continue;
> +                   if (!cat_flag &&
> +                       Vect_get_area_cat(aIn, aarea, afield) < 0) {
> +                       nskipped[0]++;
> +                       continue;
>  #ifdef HAVE_GEOS
> -                       if(area_relate_geos(bIn, AGeom,
> -                                           barea, operator, relate)) {
> +                       if (!BGeom)
> +                       if (!BGeom)
> +                       if (area_relate_geos(aIn, BGeom, aarea,
> +                           add_aarea(aIn, aarea, ALines, AAreas);
>                             nfound += 1;
> -                           break;
>  #endif
>                     else {
> -                       if (line_overlap_area(APoints, bIn, barea)) {
> +                       Vect_get_area_points(aIn, aarea, OPoints);
> +                       nisles = Vect_get_area_num_isles(aIn, aarea);
> +                       if (nisles >= isles_alloc) {
> +                           IPoints = G_realloc(IPoints, (nisles + 10) * sizeof(struct line_pnts *));
> +                           for (i = isles_alloc; i < nisles + 10; i++)
> +                           isles_alloc = nisles + 10;
> +                       for (i = 0; i < nisles; i++) {
> +                           isle = Vect_get_area_isle(aIn, aarea, i);
> +                           Vect_get_isle_points(aIn, isle, IPoints[i]);
> +                       if (line_overlap_area(BPoints, OPoints, IPoints, nisles)) {
>                             nfound += 1;
> -                           break;
>  #ifdef HAVE_GEOS
> -               GEOSGeom_destroy(AGeom);
> +           if (BGeom != NULL) {
> +               GEOSGeom_destroy(BGeom);
> +               BGeom = NULL;
>  #endif
> -               AGeom = NULL;
> -    /* Areas in A. */
> -    if (atype & GV_AREA) {
> -       int aarea, naareas;
> +    /* Areas in B. */
> +    if (btype & GV_AREA) {
> +       int barea, nbareas, bcentroid;
>         G_message(_("Processing areas..."));
> -       naareas = Vect_get_num_areas(aIn);
> +       nbareas = Vect_get_num_areas(bIn);
> -       G_percent(0, naareas, 2);
> -       for (aarea = 1; aarea <= naareas; aarea++) {
> +       G_percent(0, nbareas, 1);
> +       for (barea = 1; barea <= nbareas; barea++) {
> -           G_percent(aarea, naareas, 1);
> +           G_percent(barea, nbareas, 2);
> -           if (Vect_get_area_cat(aIn, aarea, afield) < 0) {
> -               nskipped[0]++;
> +           if ((bcentroid = Vect_get_area_centroid(bIn, barea)) < 1)
>                 continue;
> -           Vect_get_area_box(aIn, aarea, &abox);
> -           abox.T = PORT_DOUBLE_MAX;
> -           abox.B = -PORT_DOUBLE_MAX;
> -#ifdef HAVE_GEOS
> -               AGeom = Vect_read_area_geos(aIn, aarea);
> -#endif
> -               if (!AGeom)
> -                   G_fatal_error(_("Unable to read area id %d from vector map <%s>"),
> -                                 aarea, Vect_get_full_name(aIn));
> +           if (!cat_flag &&
> +               Vect_get_area_cat(bIn, barea, bfield) < 0) {
> +               nskipped[1]++;
> +               continue;
> -                   int bline;
> +           Vect_get_area_box(bIn, barea, &bbox);
> +           bbox.T = PORT_DOUBLE_MAX;
> +           bbox.B = -PORT_DOUBLE_MAX;
> +                   int aline;
> +                       continue;
> +                   /* Check type */
> +                       continue;
>                     if (!cat_flag &&
> -                       nskipped[1]++;
> +                       nskipped[0]++;
>                         continue;
>  #ifdef HAVE_GEOS
> -                           add_aarea(aIn, aarea, ALines, AAreas);
> +                       if (!BGeom)
> +                           BGeom = Vect_read_area_geos(bIn, barea);
> +                       if (!BGeom)
> +                           G_fatal_error(_("Unable to read area id %d from vector map <%s>"),
> +                                         barea, Vect_get_full_name(bIn));
>                             nfound += 1;
> -                           break;
>  #endif
>                     else {
> +                       if (BPoints->n_points == 0) {
> +                           Vect_read_line(bIn, BPoints, NULL, bcentroid);
> +                           Vect_get_area_points(bIn, barea, OPoints);
> +                           nisles = Vect_get_area_num_isles(bIn, barea);
> +                               isle = Vect_get_area_isle(bIn, barea, i);
> +                               Vect_get_isle_points(bIn, isle, IPoints[i]);
> -                       if (line_overlap_area(BPoints, aIn, aarea)) {
> +                       if (line_overlap_area(APoints, OPoints, IPoints, nisles)) {
>                             nfound += 1;
> -                           continue;
> -           /* x Areas in B */
> -               int naisles;
> -               int found = 0;
> +           /* x Areas in A */
> -               /* List of areas B */
> +               /* List of areas A */
> -               /* Make a list of features forming area A */
> -               Vect_reset_list(LList);
> +                   int found = 0;
> +                   int aarea, acentroid;
> -               Vect_get_area_boundaries(aIn, aarea, BoundList);
> -               for (i = 0; i < BoundList->n_values; i++) {
> -                   Vect_list_append(LList, abs(BoundList->value[i]));
> +                       continue;
> -               naisles = Vect_get_area_num_isles(aIn, aarea);
> +                   if ((acentroid = Vect_get_area_centroid(aIn, aarea)) < 1)
> +                       continue;
> -               for (i = 0; i < naisles; i++) {
> -                   int j, aisle;
> +                   if (!cat_flag &&
> +                       nskipped[0]++;
> +                       continue;
> -                   aisle = Vect_get_area_isle(aIn, aarea, i);
> -                   Vect_get_isle_boundaries(aIn, aisle, BoundList);
> -                   for (j = 0; j < BoundList->n_values; j++) {
> -                       Vect_list_append(LList, BoundList->value[j]);
> +                   if (operator != OP_OVERLAP) {
> +#ifdef HAVE_GEOS
> +                       if (!BGeom)
> +                       if (!BGeom)
> +                           found = 1;
> +#endif
> +                   else {
> -               Vect_select_areas_by_box(bIn, &abox, TmpList);
> +                       /* A inside B ? */
> +                       Vect_read_line(aIn, APoints, NULL, acentroid);
> +                           found = 1;
> -               for (i = 0; i < LList->n_values; i++) {
> -                   int j;
> +                       /* B inside A ? */
> +                       if (!found) {
> +                           struct bound_box abox;
> -                   aline = abs(LList->value[i]);
> -                   Vect_read_line(aIn, APoints, NULL, aline);
> +                           Vect_get_area_box(aIn, aarea, &abox);
> +                           abox.T = PORT_DOUBLE_MAX;
> +                           abox.B = -PORT_DOUBLE_MAX;
> -                   for (j = 0; j < TmpList->n_values; j++) {
> -                       int barea, bcentroid;
> +                           if (Vect_point_in_area(BPoints->x[0], BPoints->y[0], aIn,
> +                                                  aarea, &abox)) {
> +                               found = 1;
> -                       barea = TmpList->id[j];
> -                           nskipped[1]++;
> -                           continue;
> +                       /* A overlaps B ? */
> +                       if (!found) {
> +                           Vect_get_area_boundaries(aIn, aarea, BoundList);
> +                           for (i = 0; i < BoundList->n_values; i++) {
> +                               Vect_read_line(aIn, APoints, NULL, abs(BoundList->value[i]));
> +                                   found = 1;
> +                                   break;
> -                       /* Check if any centroid of area B is in area A.
> -                        * This test is important in if area B is completely within area A */
> -                       if ((bcentroid = Vect_get_area_centroid(bIn, barea)) > 0)
> -                           Vect_read_line(bIn, BPoints, NULL, bcentroid);
> -                       else {
> -                           double x, y;
> +                       if (!found) {
> +                           int j, naisles;
> -                           Vect_get_point_in_area(bIn, barea, &x, &y);
> -                           Vect_reset_line(BPoints);
> -                           Vect_append_point(BPoints, x, y, 0.0);
> +                           naisles = Vect_get_area_num_isles(aIn, aarea);
> +                           for (j = 0; j < naisles; j++) {
> -#ifdef HAVE_GEOS
> -                               found = 1;
> -                               break;
> +                               isle = Vect_get_area_isle(aIn, aarea, j);
> +                               Vect_get_isle_boundaries(aIn, isle, BoundList);
> +                                       found = 1;
> +                                       break;
> +                               if (found)
> +                                   break;
> -#endif
> -                       else {
> -                           if (Vect_point_in_area(BPoints->x[0], BPoints->y[0], aIn,
> -                                                  aarea, &abox)) {
> -                               found = 1;
> -                               break;
> -                           /* Check intersectin of lines from List with area B */
> -                               found = 1;
> -                               break;
>                     if (found) {
> -                       nfound += 1;
> -                       break;
> +                       nfound += 1;
>  #ifdef HAVE_GEOS
> +               BGeom = NULL;
>  #endif
> -               AGeom = NULL;
> @@ -334,9 +411,7 @@
>      Vect_destroy_line_struct(APoints);
>      Vect_destroy_line_struct(BPoints);
>      Vect_destroy_list(BoundList);
> -    Vect_destroy_list(LList);
>      Vect_destroy_boxlist(List);
> -    Vect_destroy_boxlist(TmpList);
>      return nfound;
> Modified: grass/branches/releasebranch_7_4/vector/v.select/write.c
> --- grass/branches/releasebranch_7_4/vector/v.select/write.c    2018-05-16 19:42:14 UTC (rev 72714)
> +++ grass/branches/releasebranch_7_4/vector/v.select/write.c    2018-05-16 19:49:20 UTC (rev 72715)
> @@ -6,7 +6,7 @@
>                  struct Map_info *Out, int table_flag, int reverse_flag,
>                  int nfields, int *fields, int *ncats, int **cats)
> -  int i, f, j, aline, nalines;
> +    int i, f, j, aline, nalines;
>      int atype;
>      struct line_pnts *APoints;
> @@ -59,6 +59,7 @@
>         if (!table_flag && (IFi != NULL)) {
>             for (i = 0; i < ACats->n_cats; i++) {
> +               f = -1;
>                 for (j = 0; j < nfields; j++) { /* find field */
>                     if (fields[j] == ACats->field[i]) {
>                         f = j;
> @@ -65,8 +66,10 @@
>                         break;
> -               cats[f][ncats[f]] = ACats->cat[i];
> -               ncats[f]++;
> +               if (f >= 0) {
> +                   cats[f][ncats[f]] = ACats->cat[i];
> +                   ncats[f]++;
> grass-commit mailing list
> grass-commit at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-commit
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
