[GRASS-dev] [GRASS GIS] #3563: v.in.ogr can't create tables in GRASS 7.4
GRASS GIS trac at osgeo.org
Thu May 17 22:35:24 PDT 2018
  Reporter:  pierreroudier  |      Owner:  grass-dev@…
      Type:  defect         |     Status:  reopened
  Priority:  normal         |  Milestone:  7.4.1
 Component:  Vector         |    Version:  7.4.0
Resolution:                 |   Keywords:  v.in.ogr
       CPU:  Unspecified    |   Platform:  Unspecified
Comment (by sbl):
 Quoting identifiers (as also described in the link you provided) should
 work...
 However, this would require significant changes, as modules (subsequent to
 v.in.ogr) are not necessarily able to handle quoted identifiers.
 In addition, this SQL standard is not implemented in all DBMS equally.
 E.g. MySQL uses backticks for quoting (instead of quotes).
 See also: #3071
Ticket URL: <https://trac.osgeo.org/grass/ticket/3563#comment:8>
