[GRASS-dev] [GSoC] Improve GRASS GIS integration in QGIS 3
Radek Novotný
radeknovotny94 at gmail.com
Sun May 20 16:04:34 PDT 2018
Hi all,
this is my Week 1 report for my GSoC Project.
1) What did I complete this week?
I started work on implementing an initial version of Python library for
generating UI files used by Processing plugin based on GRASS modules XML
description. Unfortunately, I was not able to finish this task in time,
because of I stuck in an automated generation of XML description from GRASS
[1]. So I have not enough sources for implementation and test of the
parser. [2]
2) What am I going to achieve for next week?
I want to finish work from the Week 1 and also complete the goal of week 2
- Integration of generated description UI files from initial Python library
to Processing plugin in order to generate GUI dialogue for GRASS modules.
3) Is there any blocking issue?
I am blocked with generating XML descriptions from GRASS. [1]
Thank you.
Radek
[1]
https://github.com/radeknovotny94/GRASS_Parse_to_QGIS_UI/blob/master/generate_batch_for_xml.py
[2]
https://github.com/radeknovotny94/GRASS_Parse_to_QGIS_UI/blob/master/GRASSDescribtionParser.py
2018-05-16 14:32 GMT+02:00 Radek Novotný <radeknovotny94 at gmail.com>:
> Hi!
> I added my Bonding Period Report to my project wiki page. [1]
> Briefly:
> What did you get done this period:
> 1. Introduce myself in dev list, get in contact with my mentors and
> discuss the design of functions
> 2. Prepare the wiki page about the project
> 3. Set up the GitHub repository of the project
> 4. Set up a developer environment
> What do you plan on doing next week?
> Implement an initial version of Python library for generating UI files
> used by Processing plugin based on GRASS modules XML description.
> Are you blocked on anything?
> No, I am not blocked.
> [1] https://trac.osgeo.org/grass/wiki/GSoC/2018/IntegrationInQGIS3
>> Hi all,
>> In this thread, I want to inform you about my progress with this SoC
>> project. Also, I am very interested in knowing what GRASS GIS community
>> thinks of it, all suggestions and ideas are welcome!
>> Below are the links to my GSoC proposal [1], wiki [2] and GitHub
>> repository [3].
>> [1] https://docs.google.com/document/d/1XlxRHvtaiebVIOvlq8G6
>> Q5FuUkFigZ8DlQbaQ-y9keQ/edit
>> [2] https://trac.osgeo.org/grass/wiki/GSoC/2018/IntegrationInQGIS3
>> [3] https://github.com/radeknovotny94/GRASSIntegrationInQGIS3
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180521/d8272038/attachment-0001.html>
