[GRASS-dev] [GRASS GIS] #3564: Inconsistent results from qsort callback in g.mkfontcap
trac at osgeo.org
Mon May 21 13:54:14 PDT 2018
Reporter: yugr | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.6.0
Component: Default | Version: 7.4.0
Resolution: | Keywords: qsort callback
CPU: All | Platform: All
Changes (by mmetz):
* keywords: => qsort callback
* milestone: => 7.6.0
Comment:
Replying to [ticket:3564 yugr]:
> Hi,
> qsort callback compare_fonts in g.mkfontcap may return invalid result
when arguments are swapped. Such bugs may causes inconsistent order or
even crashes in some qsort implementations
(https://bugzilla.samba.org/show_bug.cgi?id=3959).
> The issue has been detected when running standard testsuite under
SortChecker? (https://github.com/yugr/sortcheck):
> g.mkfontcap[15109]: qsort: comparison function is not symmetric
(comparison function 0x4023c0 (/build/grass-7.0.3/dist.x86_64-pc-linux-
gnu/bin/g.mkfontcap+0x4023c0), called from 0x4017a8
(/build/grass-7.0.3/dist.x86_64-pc-linux-gnu/bin/g.mkfontcap+0x4017a8),
cmdline is "/build/grass-7.0.3/dist.x86_64-pc-linux-gnu/bin/g.mkfontcap
-s")
> Problem is in lines
> if (aa->type != bb->type)
> return (aa->type > bb->type);
> which should be replaced with something like
> return (aa->type > bb->type) ? 1 : -1;
Fixed in trunk r72727.
> As a side note, many qsort callbacks in Grass are vulnerable to integer
overflows e.g. cmp_edge in ./lib/vector/neta/spanningtree.c:
> return ((edge_cost_pair *) pa)->cost - ((edge_cost_pair *)
pb)->cost;
Fixed in trunk r72728.
> or longcmp in ./raster/r.kappa/prt_mat.c:
> return (*a - *b);
Fixed in trunk r72729.
> and many many others.
If you already have a list of these many other problems, can you provide
such a list? That would be very helpful.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3564#comment:1>
