[GRASS-dev] [GRASS GIS] #3565: Porting Python Scripting Library to Python 3
trac at osgeo.org
Mon May 21 18:18:43 PDT 2018
Reporter: annakrat | Owner: grass-dev@…
Type: task | Status: new
Priority: normal | Milestone: 8.0.0
Component: Python | Version: svn-trunk
Resolution: | Keywords: gsoc2018, python3
CPU: Unspecified | Platform: All
Comment (by annakrat):
I changed Sanjeet's patch to change the behavior of encode and decode
functions in utils.py, so that they don't accept anything else than string
or bytes with Python3. Before they could be used with int, floats and
None, but it's supposed to do encoding/decoding not converting, that
should be done explicitly. To not break existing code, new behavior is
only with Python 3.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3565#comment:1>
