[GRASS-dev] [GRASS GIS] #3565: Porting Python Scripting Library to Python 3
GRASS GIS trac at osgeo.org
Wed May 23 13:56:40 PDT 2018
  Reporter:  annakrat     |      Owner:  grass-dev@…
      Type:  task         |     Status:  new
  Priority:  normal       |  Milestone:  8.0.0
 Component:  Python       |    Version:  svn-trunk
Resolution:               |   Keywords:  gsoc2018, python3
       CPU:  Unspecified  |   Platform:  All
Comment (by annakrat):
 Actually what I meant is using the encoding parameter only for stdin,
 stderr and stdout, the same way as
 [https://docs.python.org/3.6/library/subprocess.html#subprocess.Popen
 Python Popen class]. The arguments are already being encoded in
 start_command function. BTW, if you submit a patch, it should somehow
 work, I can see just by looking at it that it can't work. Or call it
 pseudocode in that case.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3565#comment:2>
