[GRASS-dev] v.stream.order NC dataset, segmentation fault 11
darcydog
daviddralle at gmail.com
Thu May 24 11:11:37 PDT 2018
I'm running GRASS 7.4.0 on OSX 10.13.1 High Sierra.
When I run the v.stream.order command exactly as described on the docs page
under the example "Stream order computation based on North Carolina
location":
https://grass.osgeo.org/grass74/manuals/addons/v.stream.order.html
I get a segmentation fault: 11
Is anyone familiar with this error?
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
