[GRASS-dev] GSoC 2018 report week 01 - GRASS GIS module for Sentinel-2 cloud and shadow detection
Stefan Blumentrath
Stefan.Blumentrath at nina.no
Fri May 25 02:19:25 PDT 2018
Ciao Roberta,
Thanks, that was exactly what I had in mind!
When you find the time you could consider the following further improvements:
* Scaling in the beginning: Currently input is scaled with a hard-coded factor, that is not necessarily generic. You could either:
1. Drop scaling completely and document in the manual how input should be scaled. Esp. if the input to your algorithm is output from i.atcorr, as i.atcorr has a scaling option for output.
2. Make scaling factor a parameter that users can provide (would be useful if atmospheric correction is performed with other tools than i.atcorr)
* Band statistics: It seems you are computing “zonal statistics” with just one zone which in practice will be a sort of global maximum per band. In that case you do not need a map and can use a constant in r.mapcalc.
If you need to use global maximum reflectance per band, you could use:
gscript.parse_command(‘r.info’, flags=’g’, …) if the maximum for the entire map is needed. This would be the fastest option.
If you need to use maximum within current computational region (or e.g. with a different mask applied) you could use:
gscript.parse_command(‘r.univar’, flags=’g’, …); then statistics are computed
From that you get “max” as a variable.
* Also having an eye on coding style (pep8 in this case) from the beginning, can be very helpful, especially in the beginning (at least that is my experience). To start with you could check your code as described here:
https://trac.osgeo.org/grass/wiki/Submitting/Python#Style A more comprehensive tutorial can be found e.g. here: https://www.datacamp.com/community/tutorials/pep8-tutorial-python-code
Just for inspiration…
Kind regards,
Stefan
From: Roberta Fagandini <robifagandini at gmail.com>
Sent: onsdag 23. mai 2018 17.07
To: GRASS developers list <grass-dev at lists.osgeo.org>
Cc: Stefan Blumentrath <Stefan.Blumentrath at nina.no>; Roberto Marzocchi <roberto.marzocchi at gmail.com>; Moritz Lennert <mlennert at club.worldonline.be>; soc at lists.osgeo.org
Subject: Re: [GRASS-dev] GSoC 2018 report week 01 - GRASS GIS module for Sentinel-2 cloud and shadow detection
Hi all!
I have just added a new version of the grass python script to my GitHub repository [0].
I tried to clean up the code.
As always, any feedback is welcome!
Thanks in advance!
Roberta
[0] https://github.com/RobiFag/GRASS_clouds_and_shadows
2018-05-21 15:19 GMT+02:00 Roberta Fagandini <robifagandini at gmail.com<mailto:robifagandini at gmail.com>>:
Ciao Stefan!
2018-05-20 21:44 GMT+02:00 Stefan Blumentrath <Stefan.Blumentrath at nina.no<mailto:Stefan.Blumentrath at nina.no>>:
Ciao Roberta,
Thanks for the comprehensive report!
One general hint: Even if the drawback is complex expression(s) I would suggest merging r.mapcalc calls. That can improve performance quite a bit (less data read and written) and reduces the need to manage temporary data.
See also: https://grass.osgeo.org/<https://grass.osgeo.org/grass74/manuals/r.mapcalc.html#multiple-computations>grass74<https://grass.osgeo.org/grass74/manuals/r.mapcalc.html#multiple-computations>/manuals/r.mapcalc.html#multiple-computations<https://grass.osgeo.org/grass74/manuals/r.mapcalc.html#multiple-computations>
If you don't need the first_... To fifth_... files later, I would even say everything in 3rd_procedure.py until r.to.vect could be solved in a single mapcalc operation...
Thank you so much for your hints! I'm trying to clean up the code without creating a too complex expression..I hope to share the new version by this evening or tomorrow at the latest.
Kind regards and again thank for your GSoC work,
Stefan
Thanks again!!
Roberta
From: grass-dev <grass-dev-bounces at lists.osgeo.org<mailto:grass-dev-bounces at lists.osgeo.org>> on behalf of Roberta Fagandini <robifagandini at gmail.com<mailto:robifagandini at gmail.com>>
Sent: Sunday, May 20, 2018 4:33:57 PM
To: soc at lists.osgeo.org<mailto:soc at lists.osgeo.org>; GRASS developers list
Subject: [GRASS-dev] GSoC 2018 report week 01 - GRASS GIS module for Sentinel-2 cloud and shadow detection
Hi all!
I'm Roberta Fagandini and I'm working on my GSoC project, a GRASS GIS module for Sentinel-2 cloud and shadow detection.
This is my report for the first week of coding.
Since my progress has been a bit faster than expected I have already discussed with my mentors about further additions to the project. Therefore I have already updated my wiki page [0] changing the timeline. In this way, I will be able to release a more complete module.
1) What did I complete this week?
* Checked the prototype version of the algorithm for cloud and shadow detection
* Tested it
* I better studied the documentation of the GRASS Python Scripting Library and started coding the GRASS python script following the workflow schema prepared during the bonding period [1]
* Coded the 'data preparation' phase
* Coded the clouds detection procedure
* Added this first part of python script to my GitHub repository [2]
* Discussed with my mentors about further additions
* Discussed with the community about testing phase. I received some feedback and some developers stepped forward to help me in testing the algorithm
* Shared progress with the community
Unfortunately, I wasn't able to code on Thursday because of a PhD meeting with my supervisor.
2) What am I going to achieve for next week?
* Finish the translation of the algorithm in a basic python script adding the shadows detection procedure and the steps for checking and cleaning the final outputs (see [1] for details)
* Improve the python script so as to have a "light" working python script (manage temporary file, clean up the code, etc.)
* Test it and fix bugs
* Start implementing the GUI
3) Is there any blocking issue?
No at the moment.
Best wishes,
Roberta
[0] https://trac.osgeo.org/grass/wiki/GSoC/2018/CloudsAndShadowsDetection
[1] https://drive.google.com/file/d/1KYEKvNBurBFHw1xUTLjM0PW80Z-7br81/view?usp=sharing
[2] https://github.com/RobiFag/GRASS_clouds_and_shadows
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180525/593e0e27/attachment-0001.html>
