[GRASS-dev] Improve GRASS GIS integration in QGIS 3 - Week 2 Report
Radek Novotný
radeknovotny94 at gmail.com
Sun May 27 06:06:27 PDT 2018
Hi All,
This is my report for Week 2 (May 21 - May 27):
*What did you get done this week?*
- Implementation of an initial version of the library for parsing
description files for QGIS Processing plugin. I solved the problem with
creating XML files from week 1. [1]
- Create an independent version of Processing plugin for development. [1]
- Try to create GUI Integration from generated description UI files from
initial Python library to Processing plugin [1]
Details can be found in [1].
*What do you plan on doing next week?*
- Final Python library for parsing descriptions
- Deep integration of UI descriptions to GUI Processing plugin
- Split GRASS module parameters in Processing plugin to basic and
advanced tabs.
*Are you blocked on anything?*
No, at the moment I’m not blocked.
The wiki page can be found in [3]
[1] https://github.com/radeknovotny94/GRASS_Parse_to_QGIS_UI
[2] https://github.com/radeknovotny94/GRASSIntegrationInQGIS3
[3] https://trac.osgeo.org/grass/wiki/GSoC/2018/IntegrationInQGIS3
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180527/43d58b2a/attachment.html>
