[GRASS-dev] [GRASS GIS] #3567: v.select: doubtful result with the default overlap operator selecting areas with lines
GRASS GIS trac at osgeo.org
Mon May 28 05:34:33 PDT 2018
with lines
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.4.2
 Component:  Vector       |    Version:  svn-trunk
Resolution:               |   Keywords:  v.select overlap
       CPU:  Unspecified  |   Platform:  Unspecified
Changes (by mlennert):
 * Attachment "v_select_issue_with_overlap_operator.png" added.
 image of overlap results
Ticket URL: <https://trac.osgeo.org/grass/ticket/3567>
