[GRASS-dev] Avoid the addition of @mymapset in output map name
Markus Metz markus.metz.giswork at gmail.com
Tue May 29 05:09:55 PDT 2018
Hi Roberta,
On Tue, May 29, 2018 at 1:41 PM, Moritz Lennert <
mlennert at club.worldonline.be> wrote:
> Hi Roberta,
> Le Tue, 29 May 2018 13:16:48 +0200,
> Roberta Fagandini <robifagandini at gmail.com> a écrit :
> > Hi all!
> > I'm working on the GUI of my module for clouds and shadows detection
> > in Sentinel 2 images  (GSoC 2018 project) and I have some trouble
> > with the automatic addition of the mapset name in the output maps.
> > I have several input bands imported in GRASS that I convert into float
> > value and rescale using r.mapcalc, each output map should be
> > automatically named with the inputs band name and a suffix (e.g.
> > input: nir - output: nir_float).
> > When I run the script using the GUI I have an error due to the @mapset
> > automatically added to the output map name (e.g. nir at mymapset_float).
> > At the moment, I solved the problem with a replace() function but I'm
> > not sure this can be the best solution, do you have any hint?
> A classic solution that you will find in many scripts is using split():
> mapname_without_mapset = mapname_with_mapset.split('@')[0]
there is find_file() in lib/python/script/core.py with returns a dictionary
of keys/values including the name without mapset
Markus M
> Moritz
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180529/a0f3592a/attachment.html>
