[GRASS-dev] v.kernel: should the module take into account the resolution for default output ?
Moritz Lennert
mlennert at club.worldonline.be
Tue May 29 05:21:43 PDT 2018
Le Tue, 29 May 2018 08:59:47 +0200,
Markus Metz <markus.metz.giswork at gmail.com> a écrit :
> On Mon, May 28, 2018 at 6:16 PM, Moritz Lennert <
> mlennert at club.worldonline.be> wrote:
> > Hi,
> > AFAIU kernel density calculations, one takes a number of points
> > and
> redistributes this total number across the entire region using a
> specified kernel function as estimator as to the spatial pattern of
> this redistribution. The total sum should correspond to the total
> number of points in the input. Is this understanding correct ?
> > In v.kernel, this seems to be dependent on the resolution:
> > echo "4.5,4.5" | v.in.ascii in=- sep=comma out=testpoint
> > g.region n=9 s=0 w=0 e=9 res=1
> > v.kernel in=testpoint out=testrast radius=5 kernel=gaussian --o
> > r.univar testrast
> > sum: 0.999544365566944
> > but
> > g.region n=9 s=0 w=0 e=9 res=2
> > r.univar testrast
> > sum: 0.308567902849234
> > IMHO, the sum should always be close to 1, or ?
> I think not, because the Gaussian kernel is a general Gaussian
> function with user-defined sigma = dmax / 4 [0]. The sum would be
> close to 1 only for a normal function (special case of the Gaussian
> function) with sigma determined from the observed distances. For the
> Gaussian kernel, the sum of the output raster should increase with
> higher resolution and constant sigma.
Thanks. I'll have to think about this a bit more when I have the time
to fully understand. I imagine there should be a way to calculate the
multiplier necessary to reach the correct sum using some
combination region extent, radius and resolution... But no time for
such thinking right now.
> multiplier=4 --o
> r.univar testrast
> sum: 1.23427161139693
> So this is close, but not very precise.
This was wrong as the g.region call leads to a region with res=1.8 and
so the v.kernel call should have used multiplier=3.24 which does lead
to a sum of 0.99.
But when I reduce or increase the radius this doesn't work anymore.
Don't know if this is linked in any way to the fact that extent of 9
divided by radius of 5 equals 1.8 which is exactly the resolution, or
whether this is pure chance... ;-)
Moritz
