[GRASS-dev] [GRASS-user] v.class.mlR Error
Helmut Kudrnovsky
hellik at web.de
Thu May 31 04:56:50 PDT 2018
>> for installing system wide in windows administrator rights are needed.
maybe
>> some possible source of troubles.
>The .libPaths(Sys.getenv('R_LIBS_USER')) call should set the
>installation directory to the user's. But maybe this is not guaranteed
>to be defined which wouldn't make it a good option.
checking here on my system:
> mypath <- .libPaths(Sys.getenv('R_LIBS_USER'))
> mypath
[1] "C:/Program Files/R/R-3.4.4/library"
in this situation, I need administrator rights to install packages. thus
there may be a wide range of different settings out there in the windows
wild.
>What else do you mean by catch the R output ?
There were 50 or more warnings (use warnings() to see the first 50)
Error in file(file, ifelse(append, "a", "w")) :
cannot open the connection
Calls: write.csv -> eval.parent -> eval -> eval -> write.table -> file
In addition: Warning message:
In file(file, ifelse(append, "a", "w")) :
cannot open file '.gscript_tmp_model_output_1300.csv': Permission denied
Execution halted
ERROR: There was an error in the execution of the R script.
Please check the R output.
so maybe I misread the last sentence. ;-)
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
