[GRASS-dev] [GRASS GIS] #3690: r.stats.quantile crashing with data linked through r.external
trac at osgeo.org
Thu Nov 1 00:39:45 PDT 2018
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.4.3
Component: Raster | Version: svn-releasebranch74
Resolution: | Keywords: r.external, r.stats.quantile
CPU: Unspecified | Platform: Unspecified
Comment (by mmetz):
Replying to [comment:2 neteler]:
> Replying to [comment:1 mmetz]:
> > The above commands do not work for me because basemap and covermap are
swapped
> ops, maybe I flipped that while anonymising the data using the output
from the QGIS Processing log file.
> > and the base map must be CELL type.
> Would it be possible to add a test for that?
This test exists already:
ERROR: The base map must be an integer (CELL) map
> > I am using GDAL 2.3.2.
> The machine causing problems is Linux Mint (Ubuntu). The versions I
don't have right now.
Can you please test again on this machine, directly in GRASS, and ideally
with both GRASS 7.4 and 7.6?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3690#comment:3>
