[GRASS-dev] [GRASS GIS] #3691: addon r.connectivity.distance not working
trac at osgeo.org
Thu Nov 1 10:34:37 PDT 2018
Reporter: cgarzon | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Addons | Version: 7.4.1
Resolution: | Keywords:
CPU: OSX/Intel | Platform: MacOSX
Description changed by neteler:
Old description:
> I have installed the addon r.connectivity. But when I try to use
> r.connectivity.distance I get the following error:
> GRASS 7.4.1 (nc_spm_08_grass7):~ > r.connectivity.distance
> Traceback (most recent call last):
> File
> "/Users/carolgarzon/Library/GRASS/7.4/Modules/scripts/r.connectivity.distance",
> line 242, in <module>
> TMP_PREFIX = grass.tempname(12)
> AttributeError: 'module' object has no attribute 'tempname'
> There is no manual page for this command and when I tried reinstalling I
> got:
> ADVERTENCIA: Extension <r.connectivity> already installed. Re-
> installing...
> Fetching <r.connectivity> from GRASS GIS Addons repository (be
> patient)...
> Compiling...
> File
> "/tmp/grass7-carolgarzon-7044/tmp_ooFcV/r.connectivity/scripts/r.connectivity.distance",
> make[1]: *** [r.connectivity.distance.tmp.html] Error 1
> Installing...
> install:
> /tmp/grass7-carolgarzon-7044/tmp_ooFcV/r.connectivity/docs/html/r.connectivity.distance.html:
> No such file or directory
> make[1]: *** [install] Error 71
> Updating addons metadata file...
> Installation of <r.connectivity> successfully finished
> What might be the problem?
New description:
File
got:
installing...
Fetching <r.connectivity> from GRASS GIS Addons repository (be patient)...
Compiling...
File
Installing...
install:
Ticket URL: <https://trac.osgeo.org/grass/ticket/3691#comment:1>
