[GRASS-dev] [GRASS GIS] #3690: r.stats.quantile crashing with data linked through r.external
trac at osgeo.org
Fri Nov 2 01:46:52 PDT 2018
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.4.3
Component: Raster | Version: svn-releasebranch74
Resolution: fixed | Keywords: r.external, r.stats.quantile
CPU: Unspecified | Platform: Unspecified
Comment (by mmetz):
Replying to [comment:4 mmetz]:
> In [changeset:"73639" 73639]:
> #!CommitTicketReference repository="" revision="73639"
> r.external: do not rely on statistics stored in metadata, they can be
approximations (fixes #3690)
These approximate statistics stored in metadata are a nightmare! The
stored maximum value in basemap is too low:
gdalinfo -mm basemap.tif
Min=1.000 Max=1061.000 Computed Min/Max=1.000,1063.000
However, metadata say
TIFFTAG_SOFTWARE=GRASS GIS 7.4.3svn with GDAL 2.2.2
in which case min and max should not be set at all. That means some other
software has edited the metadata in basemap.tif, inserting approximate and
thus wrong values.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3690#comment:5>
