[GRASS-dev] [GRASS GIS] #3688: impossible to start grass from Rstudio in Windows
trac at osgeo.org
Fri Nov 2 10:57:07 PDT 2018
Reporter: veroandreo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.4.3
Component: Default | Version: 7.4.2
Resolution: | Keywords:
CPU: Unspecified | Platform: MSWindows
Comment (by hellik):
Replying to [comment:2 rsbivand]:
> Can you grab a screen dump of the pop-up? Can you report OSGeo4W
component versions as well as R/rgrass7 versions?
System Info
GRASS version: 7.4.2
GRASS SVN revision: r73591
Build date: 2018-10-23
Build platform: x86_64-w64-mingw32
GDAL: 2.3.2
PROJ.4: 5.2.0
GEOS: 3.7.0
SQLite: 3.17.0
Python: 2.7.14
wxPython: 2.8.12.1
Platform: Windows-10-10.0.17134 (OSGeo4W)
> sessionInfo()
R version 3.4.4 (2018-03-15)
Platform: x86_64-w64-mingw32/x64 (64-bit)
Ru
Matrix products: default
locale:
[1] LC_COLLATE=German_Austria.1252 LC_CTYPE=German_Austria.1252
[3] LC_MONETARY=German_Austria.1252 LC_NUMERIC=C
[5] LC_TIME=German_Austria.1252
attached base packages:
[1] stats graphics grDevices utils datasets methods base
other attached packages:
[1] rgrass7_0.1-10 XML_3.98-1.11 sp_1.3-1
loaded via a namespace (and not attached):
[1] compiler_3.4.4 grid_3.4.4 lattice_0.20-35
first missing dll is ''iconv.dll'', then other missing dlls pops up.
step by step adding the missing dlls, a list of them
iconv.dll
proj_5_2.dll
gdal203.dll
geos_c.dll
LIBPQ.dll
ogdi.dll
xerces-c_3_2.dll
expat.dll
jpeg.dll
netcdf.dll
sqlite3.dll
spatialite.dll
all of them are living in ''C:\OSGeo4W64\bin''
Ticket URL: <https://trac.osgeo.org/grass/ticket/3688#comment:5>
