[GRASS-dev] [GRASS GIS] #3691: addon r.connectivity.distance	not working
    trac at osgeo.org
    Mon Nov  5 13:56:54 PST 2018
  Reporter:  cgarzon    |      Owner:  grass-dev@…
      Type:  defect     |     Status:  new
  Priority:  normal     |  Milestone:  7.4.3
 Component:  Addons     |    Version:  7.4.1
Resolution:             |   Keywords:  r.connectivity
       CPU:  OSX/Intel  |   Platform:  MacOSX
Comment (by neteler):
 Replying to [comment:3 sbl]:
 > Yes, the addon is developed against upcoming 7.6 and the tempname()
 function is not part of 7.4.
 > Options would be\\
 > a) to backport it to 7.4 (its a new feature but a minor change with
 little risk...) or\\
 > b) to (at least temporarily) add the function to the addon, together wih
 a check for GRASS version\\
 > What would be the prefered solution from the core-devs perspective?
 > Option a) would solve the issue first with next point release (7.4.3),
 option b) would create some mess in the addon code (that could be removed
 later...).
 I'd go both ways: backport r73205 (found with trac - source code browser -
 "blame" function) to relbranch74 and also add it for now to the addon
 code. Then remove once 7.4.3 is out.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3691#comment:5>
