[GRASS-dev] GRASS 7.4.2 won't configure on Mac
Michael Barton Michael.Barton at asu.edu
Fri Nov 9 12:06:02 PST 2018
I'm back at my workstation I use for building GRASS. Here is the configure log. I hope someone can figure out why 7.4.2 won't configure.
Thanks
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Nov 7, 2018, at 4:52 PM, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
Any ideas at all about this????
C. Michael Barton
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu<http://csdc.asu.edu/>
On Nov 5, 2018, at 11:17 AM, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
On 2 October, I had no trouble in configuring or compiling GRASS 7.4 RC on the Mac. Today, I just tried to compile the final 7.4.2 release and it won't configure. It has an error I've never seen before. I assume it is somewhat bogus because I DO have zlib and it is in my path.  Here is the configure results. Any thoughts?
Michael
checking host system type... x86_64-apple-darwin18.0.0
checking for gcc... /Applications/GRASS-7.4.2.app/Contents/Resources/bin/clang
checking whether the C compiler (/Applications/GRASS-7.4.2.app/Contents/Resources/bin/clang  ) works... yes
checking whether the C compiler (/Applications/GRASS-7.4.2.app/Contents/Resources/bin/clang  ) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether /Applications/GRASS-7.4.2.app/Contents/Resources/bin/clang accepts -g... yes
checking for Cygwin environment... no
checking for mingw32 environment... no
checking for executable suffix... no
checking for full floating-point support... yes
checking for pwd... /bin/pwd
checking for source directory... /Users/cmbarton/grass_source/release_20181022_grass_7_4_2
checking for build directory... /Users/cmbarton/grass_source/release_20181022_grass_7_4_2
checking for svnversion... /usr/bin/svnversion
checking for MacOSX App... no
checking for MacOSX architectures... no
checking for MacOSX SDK... no
checking how to build libraries... shared
checking for additional include dirs... /Applications/GRASS-7.4.2.app/Contents/Resources/include
checking for additional library dirs... /Applications/GRASS-7.4.2.app/Contents/Resources/lib
checking for a BSD compatible install... /usr/bin/install -c
checking for flex... flex
checking for yywrap in -lfl... no
checking for bison... bison -y
checking for ranlib... ranlib
checking for ar... ar
checking for env... env
checking for perl... /usr/bin/perl
checking how to run the C preprocessor... /lib/cpp
checking for ANSI C header files... no
checking for limits.h... no
checking for termio.h... no
checking for termios.h... no
checking for unistd.h... no
checking for values.h... no
checking for f2c.h... no
checking for g2c.h... no
checking for sys/ioctl.h... no
checking for sys/mtio.h... no
checking for sys/resource.h... no
checking for sys/time.h... no
checking for sys/timeb.h... no
checking for sys/types.h... no
checking for sys/utsname.h... no
checking for libintl.h... no
checking for iconv.h... no
checking for langinfo.h... no
checking whether time.h and sys/time.h may both be included... no
checking for off_t... no
checking for uid_t in sys/types.h... no
checking return type of signal handlers... int
checking for ftime... no
checking for gethostname... no
checking for gettimeofday... no
checking for lseek... no
checking for nice... no
checking for time... no
checking for uname... no
checking for seteuid... no
checking for setpriority... no
checking for setreuid... no
checking for setruid... no
checking for drand48... no
checking for putenv... no
checking for setenv... no
checking for nanosleep... no
checking whether setpgrp takes no argument... yes
checking for long long int... yes
checking for W11... no
checking for X... no
checking for library containing cuserid... no
checking for asprintf... no
checking for atan... no
checking for atan in -lm... yes
checking for dlsym... no
checking for dlsym in -ldl... yes
checking for iconv... no
checking for iconv in -liconv... no
checking for iconv in -lgiconv... no
checking for libiconv... no
checking for libiconv in -liconv... yes
checking for socket... no
checking for socket in -lsocket... no
configure: warning: *** Unable to locate socket() function.
checking for location of zlib includes...
checking for zlib.h... no
configure: error: *** Unable to locate zlib includes.
cmb-imaccsdc:release_20181022_grass_7_4_2 cmbarton$
C. Michael Barton
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20181109/f5ba3fd8/attachment-0001.html>
Type: application/octet-stream
Desc: config.log
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20181109/f5ba3fd8/attachment-0001.obj>
