[GRASS-dev] Issue with G76 in docker: creating a location fails in codecs.py
Markus Neteler neteler at osgeo.org
Fri Nov 9 15:39:13 PST 2018
while we meanwhile use GRASS GIS 7.6.svn in docker for months we ran
into this issue today:
root at 52e6935c3247:/grassdb# grass76 --text c 'EPSG:4326'
/actinia_core/grassdb/latlongtest
Cleaning up temporary files...
Starting GRASS GIS...
Creating new GRASS GIS location <latlongtest>...
  File "/usr/local/bin/grass76", line 2162, in <module>
    main()
  File "/usr/local/bin/grass76", line 2075, in main
    geofile=params.geofile, create_new=True)
  File "/usr/local/bin/grass76", line 1005, in set_mapset
    create_location(gisdbase, location_name, geofile)
  File "/usr/local/bin/grass76", line 807, in create_location
    epsg=epsg, datum_trans=datum_trans)
  File "/usr/local/grass-7.6.svn/etc/python/grass/script/core.py",
line 1538, in create_location
    encoding='utf-8', mode='w')
  File "/usr/lib/python2.7/codecs.py", line 898, in open
    file = __builtin__.open(filename, mode, buffering)
IOError: [Errno 2] No such file or directory:
'/actinia_core/grassdb/latlongtest/PERMANENT/MYNAME'
... why that?
root at 52e6935c3247:/grassdb# set | grep -i utf
LANG=C.UTF-8
LC_ALL=en_US.UTF-8
The directory is writable (I can mkdir the entire path without issues).
I wonder what I should look for here?
thanks for hints,
Markus
