[GRASS-dev] [GRASS GIS] #3693: Issue with G76 in docker: creating a location fails
trac at osgeo.org
Sun Nov 11 22:29:34 PST 2018
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.4.3
Component: Startup | Version: svn-releasebranch76
Resolution: | Keywords: docker g.proj
CPU: x86-64 | Platform: Linux
Comment (by neteler):
Replying to [comment:3 mmetz]:
> This does not seem to be a GRASS-related error. Considering that the
same (?) docker image works on a different system (docker images are
specific to each system, right?) and that g.proj works outside docker, I
suggest to rebuild the docker image causing trouble.
I did so, no difference. When I delete "datum.table" then I get:
(gdb) r -t epsg=4326 location=location
Starting program: /usr/local/grass-7.6.svn/bin/g.proj -t epsg=4326
location=location
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
WARNING: Unable to open datum table file
</usr/local/grass-7.6.svn/etc/proj/datum.table>
WARNING: Datum <WGS_1984> not recognised by GRASS and no parameters found
Program received signal SIGILL, Illegal instruction.
0x00007ffff7bce060 in GPJ_osr_to_grass () from
/usr/local/grass-7.6.svn/lib/libgrass_gproj.7.6.svn.so
(gdb) bt full
#0 0x00007ffff7bce060 in GPJ_osr_to_grass () from
No symbol table info available.
#1 0x0000555555557dab in input_epsg ()
#2 0x0000555555556d57 in main ()
GRASS 7.6.svn (latlongtest3):/grassdb > ldd
/usr/local/grass-7.6.svn/lib/libgrass_gproj.7.6.svn.so | grep gdal
libgdal.so.20 => /usr/lib/libgdal.so.20 (0x00007f8ec76c3000)
GRASS 7.6.svn (latlongtest3):/grassdb > ls -la /usr/lib/libgdal.so.20
lrwxrwxrwx 1 root root 17 Feb 6 2018 /usr/lib/libgdal.so.20 ->
libgdal.so.20.3.2
GRASS 7.6.svn (latlongtest3):/grassdb > ls -la /usr/lib/libgdal.so.20.3.2
-rw-r--r-- 1 root root 16559240 Feb 6 2018 /usr/lib/libgdal.so.20.3.2
/usr/local/grass-7.6.svn/lib/libgrass_gproj.7.6.svn.so | grep proj
libproj.so.12 => /usr/lib/x86_64-linux-gnu/libproj.so.12
(0x00007fac75934000)
GRASS 7.6.svn (latlongtest3):/grassdb > ldd /usr/lib/x86_64-linux-
gnu/libproj.so.12
linux-vdso.so.1 (0x00007ffdd7ffb000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0
(0x00007f4c8142a000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f4c8108c000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f4c80c9b000)
/lib64/ld-linux-x86-64.so.2 (0x00007f4c818b2000)
GRASS 7.6.svn (latlongtest3):/grassdb > ls -la /usr/lib/x86_64-linux-
gnu/libproj.so.12
lrwxrwxrwx 1 root root 17 Jun 18 2017 /usr/lib/x86_64-linux-
gnu/libproj.so.12 -> libproj.so.12.0.0
gnu/libproj.so.12.0.0
-rw-r--r-- 1 root root 430016 Jun 18 2017 /usr/lib/x86_64-linux-
GRASS 7.6.svn (latlongtest3):/grassdb > cs2cs -v
Using from definition:
Rel. 4.9.3, 15 August 2016
I will check tomorrow if my attempt to rebuild the docker image went
wrong.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3693#comment:4>
