[GRASS-dev] [GRASS GIS] #3694: WHERE statement in v.generalize do not work
trac at osgeo.org
Tue Nov 13 06:42:20 PST 2018
Reporter: BastienFR | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: 7.4.1
Resolution: | Keywords: v.generalize
CPU: x86-64 | Platform: MSWindows
Comment (by mmetz):
Replying to [ticket:3694 BastienFR]:
> The `WHERE` statement from `v.generalize` do not seem to work anymore.
Looking at the manual G7:v.generalize:
layer=string
Layer number or name ('-1' for all layers)
A single vector map can be connected to multiple database tables. This
number determines which table to use. When used with direct OGR access
this is the layer name.
Default: -1
By default all layers are processed, in which case the cats and where
options are ignored because they require a single layer to be selected.
Results are as expected when using `v.generalize layer=1 where="CNTY<1"
Note that a boundary is generalized as soon as any of the areas it belongs
to fulfils the where condition. In a topological vector model as in GRASS,
the modification of a single boundary results in the modification of two
areas.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3694#comment:1>
