[GRASS-dev] [GRASS GIS] #3695: r.terraflow should support large file dimensions by default
trac at osgeo.org
Mon Nov 19 08:26:37 PST 2018
Reporter: mankoff | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone:
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.terraflow
CPU: Unspecified | Platform: Unspecified
Comment (by mankoff):
When I run it with type {{{int}}} it crashes with:
COMPUTING FLOW DIRECTIONS
classifying nodata (inner & boundary)
finding nodata
r.terraflow: 3scan.h:140: void scan3line(FUN&, AMI_STREAM<T>*,
AMI_STREAM<T>*, AMI_STREAM<T>*, BASETYPE, dimension_type) [with T = float;
BASETYPE = float; FUN = detectEdgeNodata; dimension_type = int]: Assertion
`ae == AMI_ERROR_END_OF_STREAM' failed.
Aborted (core dumped)
This does not occur if I use {{{long}}}.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3695#comment:4>
