[GRASS-dev] [GRASS-user] r.covar vs layerStats in R
Micha Silver
tsvibar at gmail.com
Tue Nov 20 10:59:00 PST 2018
On 11/19/18 12:41 PM, Markus Neteler wrote:
> On Sun, Nov 18, 2018 at 10:32 PM Micha Silver <tsvibar at gmail.com> wrote:
>> I am preparing a correlation matrix for 7 raster layers. The results using the r.covar module are different from the R layerStats function. I suspect this is due to handling of null cells. The R function has a parameter to remove NA cells, but the GRASS module, I think, just loops over all cells, including no value.
>> Can anyone confirm that GRASS does not deal with null cells, and that this would cause the difference in correlation results?
> Here how r.covar treats NULL cells:
> https://trac.osgeo.org/grass/browser/grass/trunk/raster/r.covar/main.c#L93
Looking at lines 94 - 100, it seems that the count variable is
incremented even when a cell value is null.
Please correct me if I'm wrong.
Since count is used in the calculation of covariance and correlation
(lines 118-132) shouldn't it contain the number only of cells with value?
Thanks
> Markus
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
