[GRASS-dev] [GRASS-SVN] r73692 - grass/trunk/lib/init
Vaclav Petras wenzeslaus at gmail.com
Thu Nov 22 06:41:44 PST 2018
On Wed, Nov 21, 2018 at 2:12 PM Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> st 21. 11. 2018 v 20:05 odesílatel <svn_grass at osgeo.org> napsal:
> > +        # clean the sqlite db
> > +        from grass.script import db as gdb
> > +        from grass.script import core as gcore
> > +        conn = gdb.db_connection()
> > +        if conn and conn['driver'] == 'sqlite':
> > +           # check if db exists
> > +           gisenv = gcore.gisenv()
> > +           database = conn['database']
> > +           database = database.replace('$GISDBASE', gisenv['GISDBASE'])
> > +           database = database.replace('$LOCATION_NAME',
> gisenv['LOCATION_NAME'])
> > +           database = database.replace('$MAPSET', gisenv['MAPSET'])
> > +           if os.path.exists(database):
> > +               message(_("Cleaning up sqlite database ..."))
> > +               gcore.start_command('db.execute', sql = 'VACUUM')
> a small note, the added code could be probably moved to new a fn eg.
> clean_db(), Ma
Yes, ideally to grass.script.setup.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20181122/363965a1/attachment.html>
