[GRASS-dev] GRASS 7.4.2 won't configure on Mac
Michael Barton Michael.Barton at asu.edu
Mon Nov 26 11:46:27 PST 2018
I just did a restore from a back up of previously compilable trunk source code. Same error. So it is something that has changed in my system. I do have cpp in /usr/bin and it was updated recently (24 October). I do not have a link /lib/cpp and don't have a non-updated Mac to see if this link did exist previously.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Nov 22, 2018, at 9:10 AM, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
Such is my plan B. Just hoping to shortcut it with an inquiry to all if anyone knows of a recent change to GRASS source that might cause this.
No obvious change to my system, but may be something not obvious of course
Michael
Michael Barton
School of Human Evolution &Social Change
...Sent from my iPad
On Nov 22, 2018, at 7:30 AM, Vaclav Petras <wenzeslaus at gmail.com<mailto:wenzeslaus at gmail.com>> wrote:
On Wed, Nov 21, 2018 at 4:22 PM Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
As far as I can tell, I do not have cpp anywhere in any of the Mac binaries I've done, although I do have a C++ compiler installed. All previous versions compiled and built without this error, and they run fine. So what was changed between 8 October and the release of 7.4.2 that makes configure fail if cpp is not found? Where should I look?
Do you mean a change in GRASS GIS source code or your system configuration (e.g. updates)? How to decide between them is to configure the last version of GRASS GIS which worked for you. If you can configure and compile from scratch that old version but not the new one, you can try a version in between these two, the go to beginning of this sentence (aka bisect). This way you find the change in GRASS GIS. In case both the old and the new version don't configure, the change is in your system.
On Nov 12, 2018, at 9:04 PM, Vaclav Petras <wenzeslaus at gmail.com<mailto:wenzeslaus at gmail.com>> wrote:
Since it's complaining about /lib/cpp,
./configure: line 5164: /lib/cpp: No such file or directory
I would say the problem is not zlib, but missing C++ compiler (at least on my machine, /lib/cpp eventually points to /usr/bin/cpp-5), although I don't know why ./configure would catch that problem earlier since a successful report contains:
  C compiler:                 clang -O2 -Wall -pedantic -Wextra
  C++ compiler:               clang++ -std=c++14 -fexceptions
The checking phase reports only about C compiler, so the difference is perhaps there.
checking for gcc... clang
checking whether the C compiler (clang -O2 -Wall -pedantic -Wextra -s) works... yes
checking whether the C compiler (clang -O2 -Wall -pedantic -Wextra -s) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether clang accepts -g... yes
On Fri, Nov 9, 2018 at 10:58 PM Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
> I could see that it could not find zlib in the configure output. I don't know why, since I DO have zlib in the appropriate place
> MIchael
> On Nov 9, 2018, at 4:21 PM, Markus Neteler <neteler at osgeo.org<mailto:neteler at osgeo.org>> wrote:
> Just scroll to the end of the file.
> ; return 0; }
> configure:5066: checking for socket in -lsocket
> configure:5083:
> /Applications/GRASS-7.4.2.app/Contents/Resources/bin/clang -o conftest
> -g -O2    -I/Applications/GRASS-7.4.2.app/Contents/Resources/include
> -L/Applications/GRASS-7.4.2.app/Contents/Resources/lib conftest.c
> -lsocket   1>&5
> ld: library not found for -lsocket
> clang-4.0: error: linker command failed with exit code 1 (use -v to
> see invocation)
> configure: failed program was:
> #line 5072 "configure"
> #include "confdefs.h"
> /* Override any gcc2 internal prototype to avoid an error.  */
> /* We use char because int might match the return type of a gcc2
>    builtin and then its argument prototype would still apply.  */
> char socket();
> int main() {
> socket()
> ; return 0; }
> configure:5131: checking for location of zlib includes
> configure:5157: checking for zlib.h
> configure:5165: /lib/cpp
> -I/Applications/GRASS-7.4.2.app/Contents/Resources/include conftest.c
> /dev/null 2>conftest.out
> #line 5160 "configure"
> #include <zlib.h>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20181126/0d36c04e/attachment-0001.html>
