[GRASS-dev] [GRASS GIS] #3697: sqlite db: automatically enable vacuum
GRASS GIS trac at osgeo.org
Fri Nov 30 05:04:16 PST 2018
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  reopened
  Priority:  normal       |  Milestone:  7.8.0
 Component:  Database     |    Version:  unspecified
Resolution:               |   Keywords:  sqlite vacuum
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by neteler):
 In [changeset:"73736" 73736]:
 #!CommitTicketReference repository="" revision="73736"
 sqlite db: automatically enable vacuum, trac #3697 (bundle backport: trunk
 r73692, r73703, r73704, r73706, r73707, r73708)
  * lib/init: clean up sqlite db if existing, see #3697
  * libpython: move clean_default_db() to setup
  * libinit: use clean_default_db() from script.setup
  * libpython: add functions to finish a GRASS session
  * libinit: start rewriting to use functions in lib/python/scripts
  * libinit: fix r73707, clean_all() takes no arguments
Ticket URL: <https://trac.osgeo.org/grass/ticket/3697#comment:10>
