[GRASS-dev] Using db.copy over proxy?
Markus Neteler
neteler at osgeo.org
Fri Nov 30 09:54:07 PST 2018
we are using GRASS GIS on a cloud VM in an intranet and have to
connect to an external PostgreSQL database through a proxy.
While the "psql" command works, db.copy complains about:
DBMI-PostgreSQL driver error:
Connection failed.
could not connect to server: No such file or directory
Is the server running locally and accepting
connections on Unix domain socket "/var/run/postgresql/.s.PGSQL.5432"?
What is the trick here?
thanks
Markus
