[GRASS-dev] [GRASS GIS] #3673: wxGUI: UnicodeEncodeError when querying vector map
    trac at osgeo.org
    Thu Oct  4 00:48:07 PDT 2018
 Reporter:  mlennert              |      Owner:  grass-dev@…
     Type:  defect                |     Status:  new
 Priority:  normal                |  Milestone:  7.8.0
Component:  wxGUI                 |    Version:  svn-trunk
 Keywords:  wxGUI query encoding  |        CPU:  Unspecified
 Platform:  Unspecified           |
 Querying a vector map, I get the following error:
   File
 "/data/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-pc-
 linux-gnu/gui/wxpython/mapwin/buffered.py", line 1379, in
 MouseActions
 self.OnLeftUp(event)
   File
 linux-gnu/gui/wxpython/mapwin/buffered.py", line 1560, in
 OnLeftUp
 y=self.mouse['end'][1])
   File
 linux-gnu/etc/python/grass/pydispatch/signal.py", line 229,
 in emit
 dispatcher.send(signal=self, *args, **kwargs)
   File
 linux-gnu/etc/python/grass/pydispatch/dispatcher.py", line
 349, in send
 **named
   File
 linux-gnu/etc/python/grass/pydispatch/robustapply.py", line
 60, in robustApply
 return receiver(*arguments, **named)
   File
 linux-gnu/gui/wxpython/mapdisp/frame.py", line 912, in Query
 self.QueryMap(east, north, qdist, rast, vect)
   File
 linux-gnu/gui/wxpython/mapdisp/frame.py", line 976, in
 QueryMap
 self.dialogs['query'] = QueryDialog(parent=self,
 data=result)
   File
 linux-gnu/gui/wxpython/gui_core/query.py", line 52, in
 __init__
 self._model = QueryTreeBuilder(self.data,
 column=self._colNames[1])
   File
 linux-gnu/gui/wxpython/gui_core/query.py", line 238, in
 QueryTreeBuilder
 addNode(parent=model.root, data=part, model=model)
   File
 linux-gnu/gui/wxpython/gui_core/query.py", line 227, in
 addNode
 addNode(parent=node, data=v, model=model)
   File
 addNode
   File
 linux-gnu/gui/wxpython/gui_core/query.py", line 230, in
 addNode
 v = str(v)
 UnicodeEncodeError
 'ascii' codec can't encode character u'\xe8' in position 25:
 ordinal not in range(128)
 g.version -g
 version=7.7.svn
 date=2018
 revision=r73472M
 build_date=2018-10-01
 build_platform=x86_64-pc-linux-gnu
 build_off_t_size=8
Ticket URL: <https://trac.osgeo.org/grass/ticket/3673>
