[GRASS-dev] [GRASS GIS] #3677: v.surf.idw does not respect mask
trac at osgeo.org
Sat Oct 6 09:47:12 PDT 2018
Reporter: dnix | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Vector | Version: 7.4.1
Keywords: v.surf.idw | CPU: Unspecified
Platform: Unspecified |
Unable to use a mask with v.surf.idw. When mask is set with r.mask, it is
ignored by v.surf.idw and the entire region is interpolated regardless of
the mask.
The documentation notes for v.surf.idw states that a mask may be used to
limit the interpolation area: "If the user has a mask set, then
interpolation is only done for those cells that fall within the mask."
Might this be similar to defect fixed for v.surf.rst in
[https://trac.osgeo.org/grass/ticket/1775 #1775]?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3677>
