[GRASS-dev] [GRASS GIS] #3678: Map Display is not updated after r.mask in executed in the Console
GRASS GIS trac at osgeo.org
Sat Oct 6 20:40:14 PDT 2018
 Reporter:  wenzeslaus                      |      Owner:  grass-dev@…
     Type:  defect                          |     Status:  new
 Priority:  minor                           |  Milestone:  7.6.0
Component:  wxGUI                           |    Version:  svn-
                                            |  releasebranch74
 Keywords:  MASK, r.mask, mapdisp, console  |        CPU:  Unspecified
 Platform:  All                             |
 In the sample NC location, add raster (using buttons or Console):
 d.rast aspect
 Activate mask using command in Console tab:
 r.mask raster=basin_50K
 But seemingly nothing happens because Map Display window is not updated.
 Same for `r.mask -r`.
 Map Display is updated when other modules are executed including r.colors,
 so the expected behavior is that the update happens also after r.mask.
 When r.mask is used from the GUI dialog/form, the Map Display is updated.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3678>
