[GRASS-dev] Access to GRASS GIS addons
Nikos Alexandris
nik at nikosalexandris.net
Fri Oct 12 03:42:55 PDT 2018
* Helmut Kudrnovsky <hellik at web.de> [2018-10-12 01:18:37 -0700]:
>>5. Ondřej suggested also another possibility: if an Addon is >installed,
>maybe
>>then, inside QGIS: GRASS GIS Plugin > GRASS GIS shell > run `r.><addon>
>--ui`
>>would suffice?
>>Any Windows user possibly to try this last option?
>What is a GRASS GIS shell within the QGIS GRASS plugin?
Helmut,
assuming all QGIS and GRASS-GIS things are installed properly (testing
now with 2.18),
- Plugins > Manage and Install Plugins... > GRASS 7
- Once installed/enabled, select a GRASS GIS Location/Mapset
directory in the Browser Panel
- Click on the "GRASS Tools" icon/button or achieve the same via
Plugins > GRASS > Open GRASS Tools
- First available option under GRASS MODULES is the 'GRASS shell'.
There, it is possible to do something like `g.region --ui`.
N
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20181012/c615d85d/attachment.sig>
