[GRASS-dev] [GRASS GIS] #3569: pyGRASS: vector attributes return None
GRASS GIS trac at osgeo.org
Sun Oct 14 04:25:38 PDT 2018
  Reporter:  lucadelu  |      Owner:  grass-dev@…
      Type:  defect    |     Status:  new
  Priority:  normal    |  Milestone:  7.4.2
 Component:  PyGRASS   |    Version:  unspecified
Resolution:            |   Keywords:  VectorTopo, attributes table
       CPU:  All       |   Platform:  All
Description changed by neteler:
Old description:
> If you try to open a vector map in a Mapset different from the current it
> seems not possible to read attributes. Running the following code from
> user1 mapset of nc_spm_08
> #counties = VectorTopo('boundary_county')
> counties = VectorTopo('boundary_county', mapset='PERMANENT')
> counties.open('r')
> first = counties[1]
> first
> first.attrs.values()
New description:
 from grass.pygrass.vector import VectorTopo
 counties.open('r')
 first = counties[1]
 first
   File "<stdin>", line 1, in <module>
 AttributeError: 'NoneType' object has no attribute 'values'
Ticket URL: <https://trac.osgeo.org/grass/ticket/3569#comment:1>
