[GRASS-dev] Access to GRASS GIS addons
    Nikos Alexandris
    nik at nikosalexandris.net
    Mon Oct 15 03:10:28 PDT 2018
Here a working solution (as explained/provided by Stefan) for the
"Processing Toolbox". Note, below "grass-ltr" maybe any grass 7.x
version, like grass-7.4.svn
1. Copy a GRASS GIS addon, say `r.example` under
C:\OSGeo4W64\apps\grass\grass-ltr\scripts\
2. Copy a Windows Batch file named after the addon, of course with the
extension of the file being `.bat` under
C:\OSGeo4W64\apps\grass\grass-7.4.svn\bin\ # r.estimap.bat
whose content should be:
@"%GRASS_PYTHON%" "%GISBASE%/scripts/<AddonName>.py" %*
3. For the description of the UI, copy `r.example.txt` under
C:\OSGeo4W64\apps\qgis\python\plugins\processing\algs\grass7\description\
The above steps will make the addon listed under the list of GRASS GIS
algorithms, inside the Processing toolbox.
4. There is another thing (yet to test): perhaps a file name r_example.py
is required under
in C:\OSGeo4W64\apps\qgis\python\plugins\processing\algs\grass7\ext
Looking at existing files there-in, they are not the "same" and I guess
it's going to be required (to understand what and how) in order to get
an addon running as expected.
Nikos
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20181015/4be213ad/attachment.sig>
